  3. How could i get a Plot with a Xaxis in volt by the ocean...
  • Replies 21
  • Views 26808
How could i get a Plot with a Xaxis in volt by the ocean script?
OLyonnais
OLyonnais over 16 years ago
Hello
I'm trying to get a plot by the ocean script but when i observe my 3 outputs signals i have 3 lines (constant) whereas when i lauch that by a classical simulation (interface analog environment) i obtain the correct waveform with the Vn in horizontal scale
Indeed, i think i have a trouble on my Xaxis because in one case (by the analog environment) "Vn" (my sweep variable from 0 to 1.1) is on the X axis and on the other case, i have nothing, the time i think...
ocnWaveformTool( 'wavescan )
simulator( 'spectre )
design(     "/../spectre/schematic/netlist/netlist")
resultsDir( "/../spectre/schematic" )
definitionFile(
    "models.scs"
analysis('dc ?saveOppoint t  ?param "Vn"  ?start "1.1"
        ?stop "0"  ?lin "1000"  )
desVar(      "Vn" 1    )
temp( 27 )
run()
selectResult( 'dcOp )
plot(getData("/S") getData("/SB") getData("/BL") )
thank you for your answer and sorry for my "basic" english
  • OLyonnais
     EDIT NOTES
    The monteCarlo simulation works (successful)!!
     but just there are these lines of error concerning "the evaluating ocean monteExpr".
  • ebecheto
    ebecheto over 16 years ago
     Come one Mr Olyonnais! You forget a double quote of the delay. Check your expression syntax.
     monteExpr( "Delay_WL_S_rise" "delay(clip(v(\"/WL\" ?result \"tran-tran\")"
    Check your expression step by step when your not sure.
    So are you Lyonnais or Niçois ?
    ++Ed
    Axel,
    In the psf directory, you should find a file artil.log which may well reveal the cause of the error - any error messages will be shown there.
    Best Regards,
  • OLyonnais
     Hi eBecheto
    I think you have not the entire expression because i didn't forget anything....
    monteExpr( "Delay_WL_S_rise" "delay(clip(v(\"/WL\" ?result \"tran-tran\") 2.871401e-08 3.685221e-08) VAR(\"Vdd_half\") 1 \"either\" clip(v(\"/S\" ?result \"tran-tran\") 2.871401e-08 3.685221e-08) 0.55 1 \"either\" 0 0 nil nil)" )
     The problem that i have, is that my monteCarlo analysis is successful but i obtain an error on the evaluation of the monteExpr.
    ps: I'm lyonnais ;) but living in Nice.
  • OLyonnais
     Andrew,
     here the artil.log with a montecarlo of 2 runs
    Loading auCore.cxt
    Loading awv.cxt
    "mps7010"
    > Loading oasis.cxt
              Results "subckts-info" are not available for
              "../psf/logFile". Use results() for a list of available
              results.
    Loading analog.cxt
    Loading asimenv.cxt
    Loading spectrei.cxt
              Results "mc1-001_subckts-info" are not available for
              "../psf/logFile.tmp". Use results() for a list of available
              results.
              Results "tran-tran" are not available for
              results.
              Results "mc1-002_subckts-info" are not available for
              results.
              results.
    I checked that the desVar is saved in the variables_File:
    "Vdd_half" "variable" ( 550e-3 ) PROP( )
    http://rs269tg.rapidshare.com/files/367939433/665862/error.jpeg
    Hi Axel,
    Try changing the "tran-tran" in your expression to "tran" or 'tran :
    monteExpr( "Delay_WL_S_rise" "delay(clip(v(\"/WL\" ?result 'tran") 2.871401e-08 3.685221e-08) VAR(\"Vdd_half\") 1 \"either\" clip(v(\"/S\" ?result 'tran) 2.871401e-08 3.685221e-08) 0.55 1 \"either\" 0 0 nil nil)" )
    It's best to use the "aliased" names (this is covered in the "Advanced Analysis" manual in the IC release, if my memory is correct).
  • OLyonnais
     Andrew,
    Thank you again you solved my problem...
    I change the "tran-tran" in your expression to 'tran : before i corrected the little mistake here: 'tran"
     So i put 'tran and now its perfect !!
    Could you explain me the difference between "tran" and "tran tran " ? please
    thank you again Andrew.
    Axel
    Hi Axel,
    Apologies for my typo - meant to omit the final quote, of course.
    If you have a look in <ICinstDir>/doc/aatoolsuser/aatoolsuser.pdf and search for "Data Name Aliasing" you'll find a section which describes. There are some following sections which also describe creating expressions compatible with monte carlo.
    The problem with using tran-tran is that this can result in picking (say) the nominal results rather than the result from each monte carlo point. The benefit of the "aliased" name (i.e 'tran or "tran") is that it will always pick the current point's run (even though it may be actually called "mc1_tran-montecarlo" or something like that).
    Hope that helps!
  • OLyonnais
    Ok i understand. Just for information, only the 'tran syntax work. "tran" doesn't work. Regards, Axel
    Axel,
    Are you sure? It should work with either 'tran or "tran" (of course in the monteExpr it would have to be \"tran\" because the string is within quotes already). Of course it wouldn't have worked with 'tran" because that was me making a silly mistake.
    Inside the code, it will treat a symbol or string the same, as far as I know (for this situation).
    I just tried my example with v(\"/net5\" ?result \"tran\") and it worked with no problems.
