  3. How could i get a Plot with a Xaxis in volt by the ocean...
  • Replies 21
  • Views 26818
How could i get a Plot with a Xaxis in volt by the ocean script?
OLyonnais
OLyonnais over 16 years ago
Hello
I'm trying to get a plot by the ocean script but when i observe my 3 outputs signals i have 3 lines (constant) whereas when i lauch that by a classical simulation (interface analog environment) i obtain the correct waveform with the Vn in horizontal scale
Indeed, i think i have a trouble on my Xaxis because in one case (by the analog environment) "Vn" (my sweep variable from 0 to 1.1) is on the X axis and on the other case, i have nothing, the time i think...
ocnWaveformTool( 'wavescan )
simulator( 'spectre )
design(     "/../spectre/schematic/netlist/netlist")
resultsDir( "/../spectre/schematic" )
definitionFile(
    "models.scs"
analysis('dc ?saveOppoint t  ?param "Vn"  ?start "1.1"
        ?stop "0"  ?lin "1000"  )
desVar(      "Vn" 1    )
temp( 27 )
run()
selectResult( 'dcOp )
plot(getData("/S") getData("/SB") getData("/BL") )
thank you for your answer and sorry for my "basic" english
  • OLyonnais
    Apologies for that... i forgot the back slash !!
    Axel
