  3. Import a GDS File: Xstream Failed
  • Replies 8
  • Subscribers 152
  • Views 20106
mihagi
mihagi over 16 years ago
Hello, i am a new user of cadence. I am trying to import a GDS file but I got an error.
I am running Cadence Version 6.1.3 07/31/20 , I have a technology file attached. I have created  a new library and then I select File-Import.
 If I select VHDL, Spice, DEF, LEF it works; the import window appears. If I select Stream instead in the CIW I can read:
 "  XStream/strminui is running (PID = ipc:1 )...
XStream failed "
and  nothing happens.
What can I do to import my GDS file?
 Gianluca
  • kbhow
    kbhow over 16 years ago
    Hi Gianluca,
    Do you have any log file? It is very hard to troubleshoot since we didn't see any issue in streaming in GDS. A log file will be very useful.
    Rdgs,
    How
  • mihagi
    Please find attached the CDS.log file.
    If you need to check other log files, please let me know wich one and where I can find it.
    Thank you very much for your help.
    Regards
    Gianluca
    CDS.log.1.zip
  • skillUser
    skillUser over 16 years ago
    Hi Gianluca,
    I could not see anything obvious in the CDS.log as the cause of the problem.  I suggest that you contact your local Cadence Customer Support (or internal support etc.) to submit a Service Request.
    regards,
    Lawrence.
  • mihagi
     Ok, I will contact the local customer support. It's really strange because if i try to use export -> stream, it works!
    If I will be able to find the solution I will post it. Thanks.
    Gianluca
  • Quek
    Quek over 16 years ago
    Hi Gianluca
    As a workaround, you can run strmin cmd in your working directory in a terminal window. : )
    terminal>strmin -library ABC -strmFile /path/myFile.gds
    Best regards
    Quek
  • lrl12skdev
    lrl12skdev over 16 years ago
    HI,
    I think it would be helpful if you have a look on your PIPO.log file. I'm sure the details for your streamin error are listed there.
     regards,
    rence
  • Quek
    Hi rence
    Good point. : )  Just a minor correction. The default file name PIPO.log is for pipo from IC5141. IC61 uses XStream and has the default log file name "strmin.log" when importing gds files.
    Best regards
    Quek
  • lrl12skdev
     Hi Quek,
     I am using both on a per proj basis so my apologies for mixing it up. :D
    Thanks anyway for the clarification.
    BR,  rence
