  3. How to check if a particular view of a cell exists?
  • Views 20245
Ronen Cohen
Ronen Cohen over 16 years ago
Hi, I was using the following command to check if a view of a cell exists: >> if((NewCellId = dbOpenCellViewByType(MyLibName myCell newView nil "r")) then >> .... It doesn't work. It will always create a dbId for that view even if that is the first time. Is there a different way to check if the cells exist? Thanks in advance, Ronen.
  • skillUser
    skillUser over 16 years ago
    Hi Ronen,
    You can use the ddGetObj() function to check for the existence of a cellview in the file system. I think your parentheses are misplaced in the above example, the then and associated code needs to be before the close paren - dbOpenCellViewByType will return nil if the cellview doesn't exist, but you might also get a warning, so the ddGetObj method might be preferable.
    Best regards,
    Lawrence.
  • Ronen Cohen
    Thanks Lawrence,
    It worked as I intended using the ddGetObj().
    Ronen.
