  3. Importing GDS file in cadence
  • Replies 14
  • Subscribers 153
  • Views 25802
Selvaa
Selvaa over 15 years ago
I would like to import gds file,which available in my server.
I have used import->stream option..
after I import I am getting  "Error load : Cant access file "
I tried with few other items :
"Value of the option 'techfileName', defined in the template file,contains spaces,spaces not allowed."
I have to use Opus DB or ASCII Dump or Techfile.....?
 If I try to import using OpusDB It says "FATAL (299): Stream out was unable to find a primary cell in the input database
Compiling Class 'layerDefinitions'.....
Compiling Class 'layerRules'...........
Thanks for your reply
  • Quek
    Quek over 15 years ago
    Hi Selvaa
    It looks like you might have specified a wrong path for your gds file. Would you please correct the path and retry?
    Best regards
    Quek
  • Selvaa
    Hi Quek,
    I imported the data,But I am not able to see the layers.
    I set all the layer " All valid".Its there anyway to see the image...?
  • Quek
    Hi Selvaa
    Do you see only a single black colour layer in the LSW? If yes, would you please try the following?
    a. In ciw, go to "Tools->Technology File Manager"
    b. In the small form that appears, select "Attach"
    c. Attach your design lib to your tech lib
    Best regards
    Quek
  • Selvaa
    I have attached with my technology file,Still I am not able to see the layer.
    If I select all then there is a layer inside the Layout Window.
    Could you help me..?
  • Quek
    Hi Selvaa
    Would you please upload your CDS.log file? Please upload the file as an attachment, not cut and paste.
    Quek
  • Selvaa
    This is the file I got it for layer map,While I stream.
    I have attached this file.
    Thanks & Regards
    Selvakumar R
  • Quek
    Hi Selvakumar
    I am unable to see the attachment. Please use the upload attachment function. There is a tab named "Option" when you reply to a message. Select the tab.
    Best regards
    Quek
  • Selvaa
    Hi Quek,
    I have attached the file,Please help me to streamin the file.
    test_param.zip
  • Quek
    Hi Selvakumar
    Thanks for the files. The gds file itself is the problem. It is empty. So it is expected that you get an empty layout.
    Best regards
    Quek
  • Selvaa
    Hi Quek,
    But I am able to see some image without any layer.If I "select all" I am able to see few image but not the structure.
    Thanks & Regards
    Selvakumar R
