  3. Importing GDS file in cadence
  • Replies 14
  • Subscribers 153
  • Views 25813
Selvaa
Selvaa over 15 years ago
I would like to import gds file,which available in my server.
I have used import->stream option..
after I import I am getting  "Error load : Cant access file "
I tried with few other items :
"Value of the option 'techfileName', defined in the template file,contains spaces,spaces not allowed."
I have to use Opus DB or ASCII Dump or Techfile.....?
 If I try to import using OpusDB It says "FATAL (299): Stream out was unable to find a primary cell in the input database
Compiling Class 'layerDefinitions'.....
Compiling Class 'layerRules'...........
Thanks for your reply
  • Quek
    Quek over 15 years ago
    Hi Selvakumar
    Actually I have already checked using our gds viewer QuickView. The gds file is indeed empty. There are no layers in it. I think it is better for you to re-confirm the data with the owner.
    Best regards
    Quek
  • Selvaa
    Hi Quek,
    Thanks man, I dnt have access to download gds viewer.
    Thanks & Regards
    Selvakumar R
  • StefanSL
    StefanSL over 15 years ago
    Hi Selvakumar,
    your gds2-file contains a lot of hierarchy but no shapes at all;
    this might be the reason why you are seeing "something" but no drawing;
    what you can see are just the references to subcells; if you reduce the
    display depth ( "e" resp. Options - Display, -> "Display Levels Stop" to 0 or 1),
    you'll see the references themselves;
    i assume the file has been streamed out using a invalid layermapping, thus
    the hierarchy has been streamed out correctly but no layer-data. Try to get
    a new (and confirmed) version of your file.
    kind regards
    Stefan
  • Selvaa
    Thanks all for your immeidate support Esply Quek & SteFan"
