  3. A problem with menu
  • Views 15069
A problem with menu
Renee
Renee over 15 years ago
 I tried to insert a menu item in the CIW window by defining a procedure as below:
  procedure(build_menu()
   hiInsertBannerMenu(hiGetCIWindow()
                                 'testMenuID
                                 hiGetNumMenus(hiGetCIWindow())
In the .cdsinit file, I wrote:
load("build_menu.il")
build_menu()
I am sure that the build_menu.il file is loaded, but I have to type build_menu() in the CIW window again to insert the menu item to that window.
What I want is that this menu is added automatically every time I start icfb. How can I do that ?
Thanks in advance!
Lei
    Hi Lei,
    Call ciwMenuInit() before the hiInsertBannerMenu. This will force the standard CIW menus (which are created from a menus file) to get created at that point. Normally this is deferred until the end of the .cdsinit, so your menu gets overwritten by the standard menus otherwise.
  • Renee
    Thanks for your reply!
