  3. ADE simulation files -- error
  • Subscribers 152
  • Views 4160
Thodoros
Thodoros over 15 years ago
I am trying to assign a simulation file to a ADE run (ADE ->setup -> simulation files) which contains the simple that follows:
simulator lang=spectre
_vAddr\<3\> (Addr\<3\> 0) vsource val0=0 val1=0 period=500p width=250p type=pulse
 I have ic6.1.4 and when I execute "Netlist and Run" I get the following error:
 Error found by spectre during circuit read-in.
     ERROR (SFE-874): "/home/simop/simulation/sram_PCCA/spectre/schematic/netlist/stimuli/stem" 2: Unexpected operator "<".
What really happens is that at the ~/ ... /simulation/<design>/schematic/netlist/stimuli/ directory the copied stimuli file has errased the "\" character.
I really have to add that character and perform ADE ->Simulation ->Run in order to continue with the simulation.
Can I ovefrcome this?
Thodoros
  • Thodoros
     OK I found a walk aroud.
    Instead of writing the stimuli
    I add an extra "\" and the stimuli
    _vAddr\\<3\\> (Addr\\<3\\> 0) vsource val0=0 val1=0 period=500p width=250p type=pulse
     is OK
    Is this the proper way of writing stimuli files?
    Thodoros
    The stimulus file goes through a mapping process which allows "schematic" names to be used via the [#...] syntax. These get mapped into whatever was used in the netlist (via mapping). So you'd use something like this:
    v1 ([#bus<0>] 0) vsource type=sine freq=1M ampl=1
    v2 ([#bus<1>] 0) vsource type=sine freq=2M ampl=1.5
    v3 ([#bus<2>] 0) vsource type=sine freq=3M ampl=2.0
    v4 ([#bus<3>] [#/gnd!]) vsource type=sine freq=4M ampl=2.5
    Note that there is a bug in IC61X (CCR 752498) where this doesn't work in some cases. You need to use
    envSetVal("asimenv" "mappingMode" 'string "oss")
    Before starting ADE. And you may need to do a Simulation->Netlist->Recreate to force it to renetlist after making the change. This changes the netlist mapping back to the IC5141 method (see http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11334086 )
    Note that the instance names are presumably not that critical, so you can call them whatever you want (they don't need to map to a bus name)
  • Thodoros
     Andrew,
    Thanks for the responce on the specific issue which was quite helpful.
    I was worried some time now if we could use a bus rage (i.e. [#bus<0:15>]) in a stimulus file, or if there is a way of doing so. I understand that it is difficult for the analog to perform so, but if the bus is set to bit function could we use the range?
    Thanks in advance,
    Thodoros
    Hi Thodoros,
    Since the spectre language doesn't support buses (all the nets you see in the netlist are scalar) it doesn't really make sense to provide a whole bus (or even a multi-bit slice of a bus) such as [#bus<0:15>]. If you want to drive a vector, you should use the vector or vcd support in spectre which allows digital stimulus to be given. This is in the Setup->Simulation Files (VCD File, EVCD File, Vector File) in ADE.
  • smthiid
    smthiid over 15 years ago
    Hello Andrew,
    I googled a lot to solve my question here http://www.cadence.com/Community/forums/p/18309/1260848.aspx#1260848, and found your post.  I think it may be helpful to use a vector file to generate the control signals for my 924 bits, but I don't know how.  I actually only need to set them to be either 0's or 1's, and I think if I can name them as [#bus<1:924>] and set a vector file it should work.  Could you please give me some guidelines?  Which manual should I refer to?
    Tao
    Frank has given you the answer in your original question thread. Also, the format of the vector files is covered in the documentation (and "spectre -h vector" gives some good pointers).
