  3. use skill language to convert a picture into RGB matrix
  • Subscribers 150
  • Views 21236
imagesensor123
imagesensor123 over 15 years ago
 hi,
   is there anybody who did some work about image porcessing in cadence environment, or if there is a function can convert image into matrix, I want to extract RGB from a picture, but I didn't find a function can do this in skill manual!
welcome to your opinion!
thanks,
    First of all, what do you mean by "cadence environment"? There are lots of potential environments you could be talking about - could be Allegro, could be SimVision, could be Encounter, could be Virtuoso - etc. Secondly, what kind of file are you talking about reading? I have written some SKILL code which allows reading an XPM (X PixMap) file and generating a layout from it - mainly for creating logos on chips. XPM has the benefit of being an ASCII format. If you're trying to read generic picture formats (e.g. JPEG, PNG etc) you would probably be better off using some external program which has libraries for reading such formats, and then outputting the data in some ASCII format which can easily be read by whichever environment  you're actually talking about.
    If it's Virtuoso you're talking about, reading an image into Virtuoso is probably a rather rare or specialist requirement, so it's not that surprising there's no standard function to do this.
    Best Regards,
  • imagesensor123
         yes, I'm talking about read a picture(bmp, png or jpeg) into Virtuoso ADE, my application is a specialist requirement, and I need to read in the picture and simulate it in the ADE, so I am looking for a skill function built in, as you said, I'm afraid that  I must develop this function by myself .
         I found the interprocess communication (IPC) skill function has metioned that we can use some external tools or function (.exe) to coroperate with cadence, is it possible to use some C function to convert a picture into ASCII data, and be read into cadence by skill function, because I need to do the whole work in cadence environment alone.
    thank you very much,
    Best Regards,
    zfeng
    Hi zfeng,
    You cannot integrated C functions into the main Virtuoso executable. You will have to do it by launching some external program which converts it from a binary format file into something that can be read as an ASCII file using SKILL. There are a number of utilities and libraries (for various scripting language) out there which should allow this - why does it have to be done natively in the Cadence environment? (even if you linked in a C library, that wouldn't be the case, strictly).
  • dankert
    dankert over 15 years ago
    Andrew,
    I would actually find this functionality useful for a very different reason.  There have been a number of times where a reference image was created in another software program and I would like to simply insert the image into the cadence schematic sheet as a comment.  I have seen the image to gds conversion scripts and can certainly use them, but it would be great if there were some skill code that could take an image (Any format is fine) and convert it into a comment on the schematic sheet.
    If you come across something like this, I would certainly like to have a look at it.
    dankert
    Here's my old code to do this from an XPM file:
    /* abXpmToLayout.ils
    Author A.D.Beckett
    Group Custom IC (UK), Cadence Design Systems Ltd.
    Language SKILL
    Date Jun 15, 2001
    Modified
    By
    NOTE: This is SKILL++ code, so please preserve the .ils suffix.
    Code to read an X pixmap and draw a layout.
    The main entry function is abXpmToLayout(), which should
    be invoked with a layout window being the current window.
    Limitations/Ideas for future:
    1. This only handles up to something like 62 layers
    properly. This is because the pixmap format changes to use
    more than one character per pixel, and the code rather
    dumbly assumes that there will only ever be one. To
    be fair, setting up all the layer purpose pairs would
    be a nightmare.
    2. Could merge colours which appear similar, to avoid
    having to specify similar colours lots of times.
    3. Some convenience toggles could be added, to turn on or
    off all layers.
    Primarily this expected to be used for a small number of
    colours in the pixmap file. This can be arranged using
    other tools (xv, gimp, PC tools etc).
    These tools can also be used to convert from other formats
    to xpm.
    SCCS Info: @(#) abXpmToLayout.ils 06/15/01.15:27:13 1.4
    (importSkillVar abPixMapOptionsForm)
    ; Define classes used within the code
    (defclass abPixMap ()
    (width @initarg width @reader abPixMapGetWidth)
    (height @initarg height @reader abPixMapGetHeight)
    (colours @initarg colours @reader abPixMapGetColours)
    (pixels @initarg pixels @reader abPixMapGetPixels)
    (defclass abPixMapColour ()
    (char @initarg char)
    (red @initarg red @reader abPixMapColourGetRed)
    (green @initarg green @reader abPixMapColourGetGreen)
    (blue @initarg blue @reader abPixMapColourGetBlue)
    (lpp @reader abPixMapColourGetLpp @writer abPixMapColourSetLpp)
    * (abPixMapColourGetLpp _colour) *
    * A dummy method, so that if the colour isn't found for a *
    * character in the pixel strings, it returns nil *
    (defmethod abPixMapColourGetLpp ((_colour list))
    nil
    * (abPixMapReadFile fileName) *
    * Read a pixmap file, and return an instance of the abPixMap *
    * structure. *
    (defun abPixMapReadFile (fileName)
    (let (prt staticFound line data dimensions width height ncolours
    colourTable colourInfo red green blue pixmap)
    (unless (setq prt (infile fileName))
    (error "Could not read pixmap file %s" fileName)
    (rexCompile "static char")
    (while (and (null staticFound) (gets line prt))
    (setq staticFound (rexExecute line))
    (when staticFound
    (setq data t)
    (while (equal (setq data (lineread prt)) t) t)
    ; Swallow any warnings about closing } etc
    (getWarn)
    (close prt)
    (when (and data (nequal data t))
    ; first entry in the list will be the dimensional information
    (setq dimensions (linereadstring (car data)))
    (setq width (car dimensions))
    (setq height (cadr dimensions))
    (setq ncolours (caddr dimensions))
    (setq data (cdr data))
    ; Now read the colours
    (setq colourTable (makeTable 'colourTable nil))
    (for colour 1 ncolours
    (setq colourInfo (parseString (car data)))
    (when (cddr colourInfo)
    (sscanf (caddr colourInfo)
    "#%2x%2x%2x" red green blue
    (setarray colourTable
    (car colourInfo)
    (makeInstance 'abPixMapColour
    ?char (car colourInfo)
    ?red red || 0
    ?green green || 0
    ?blue blue || 0
    ; Now create the pixmap object
    (setq pixmap
    ?width width
    ?height height
    ?colours colourTable
    ?pixels data
    ) ; when
    pixmap
    * abPixMapDrawLayout(@key pixmap (pixelSize 0.1) *
    * (cellView (geGetEditCellView)) *
    * (origin 0:0)) *
    * Draw the layout itself from the pixmap structure. *
    (defun abPixMapDrawLayout (@key pixmap (pixelSize 0.1)
    (origin 0:0))
    (let (x y colours rectList lpp)
    (setq colours (abPixMapGetColours pixmap))
    (setq y (yCoord origin))
    ; Iterate over each row
    (foreach row (abPixMapGetPixels pixmap)
    (setq x (xCoord origin))
    (foreach pixel (parseString row "")
    ; Determine the layer purpose pair
    (setq lpp
    (abPixMapColourGetLpp (arrayref colours pixel)))
    ; Draw the rectangle
    (when (and (listp lpp) lpp)
    (setq rectList
    (cons
    (dbCreateRect
    cellView
    lpp
    (list
    (list x y)
    (list
    (plus x pixelSize)
    (difference y pixelSize)
    rectList
    (setq x (plus x pixelSize))
    (setq y (difference y pixelSize))
    ; Merge all the shapes to reduce the shape count
    (leMergeShapes rectList)
    t
    * (abPixMapCreateForm) *
    * Create the options form for the pixmap drawer. *
    * Note that all the layers aren't put on the form until *
    * the file has been read *
    (defun abPixMapCreateForm ()
    (let (fileName selectFile pixelSize scrollRegion readFile)
    (setq fileName
    (hiCreateStringField
    ?name 'fileName
    ?prompt "Pixmap File"
    ?callback "(abUpdateSelectFile)"
    (setq selectFile
    (hiCreateButton
    ?name 'selectFile
    ?buttonText "Select File"
    ?callback "(abPixMapSyncWithSelectFile)"
    (setq readFile
    (hiCreateButton
    ?name 'readFile
    ?buttonText "Read File"
    ?callback "(abPixMapReadFileCB)"
    (setq pixelSize
    (hiCreateFloatField
    ?name 'pixelSize
    ?defValue 0.1
    ?prompt "Pixel Size"
    (setq scrollRegion
    (hiCreateScrollRegion
    ?borderWidth 0
    ?name 'layers
    (hiCreateAppForm
    ?name 'abPixMapOptionsForm
    ?formTitle "Choose pixmap settings"
    ?formType 'options
    ?buttonLayout 'HideCancel
    ?fields (list
    (list fileName 0:0 405:35 105)
    (list selectFile 105:35 95:30)
    (list readFile 205:35 95:30)
    (list pixelSize 0:70 405:35 105)
    (list
    (hiCreateLabel
    ?name 'colourLab
    ?labelText "Colour"
    105:105 35:30)
    (list
    (hiCreateLabel
    ?name 'convertLab
    ?labelText "Draw"
    160:105 32:30)
    (list
    (hiCreateLabel
    ?name 'lppLab
    ?labelText "Layer"
    205:105 32:30)
    (list scrollRegion 105:130 300:200)
    * (abPixMapAddPointCB _windowId _pointList) *
    * Ignore any points entered before the pixmap has been *
    * read. *
    (defun abPixMapAddPointCB (_windowId _pointList)
    (unless (getq abPixMapOptionsForm pixmap)
    (deletePoint)
    * (abPixMapDoneCB _windowId ok points) *
    * When the points have been entered, and all is OK, proceed *
    * to fill the colour structure with the selected layer purpose *
    * pairs, and then draw the pixmap starting at the specified *
    * coordinates. *
    (defun abPixMapDoneCB (_windowId ok points)
    (let (pixmap)
    (setq pixmap (getq abPixMapOptionsForm pixmap))
    (when (and ok points pixmap)
    (abPixMapFillInLpps (getq abPixMapOptionsForm layers) pixmap)
    (abPixMapDrawLayout
    ?pixmap pixmap
    ?pixelSize (getq (getq abPixMapOptionsForm pixelSize) value)
    ?cellView (getq abPixMapOptionsForm cellView)
    ?origin (car points)
    * (abPixMapGetLayer layerString) *
    * Because we have multiple layer cyclic fields, need *
    * to extract the layer purpose pair name ourselves *
    (defun abPixMapGetLayer (layerString)
    (let (layer)
    (setq layer (linereadstring layerString))
    (list (get_string (car layer))
    (get_string (caadr layer)))))
    * (abPixMapFillInLpps region pixmap) *
    * Given the scroll region on the form, and the pixmap *
    * instance, fill in the lpp information in the colour *
    * structures, based on what was selected on the form. *
    (defun abPixMapFillInLpps (region pixmap)
    (let (colours colourNum colour)
    (setq colourNum 0)
    ; Loop through all the colour names
    (foreach colourName (getq region colourNames)
    (setq colour (arrayref colours colourName))
    (abPixMapColourSetLpp
    colour
    (and (getq (get region (concat 'convert colourNum)) value)
    (abPixMapGetLayer
    (cadddr
    (getq (get region (concat 'lpp colourNum)) value))
    (postincrement colourNum)
    * (abPixMapSyncWithSelectFile) *
    * Set up the synchronisation with the file selecter *
    (defun abPixMapSyncWithSelectFile ()
    (abSyncWithSelectFile
    abPixMapOptionsForm
    'fileName
    nil))
    * (abPixMapReadFileCB) *
    * Callback for the read file button. When this is done, it must *
    * read the pixmap structure, and fill in the scroll region with *
    * the appropriate layers. *
    (defun abPixMapReadFileCB ()
    (let (fileName pixmap)
    (setq fileName (getq (getq abPixMapOptionsForm fileName) value))
    (unless (blankstrp fileName)
    ; Read the pixmap
    (setq pixmap (abPixMapReadFile fileName))
    (when pixmap
    ; Put the layers into the scroll region
    (abPixMapFillScrollRegion
    pixmap (getq abPixMapOptionsForm layers)
    (getq abPixMapOptionsForm cellView))
    ; Record the pixmap for posterity
    (putpropq abPixMapOptionsForm pixmap pixmap)
    ; Change the enter function - primarily to change
    ; the prompt
    (changeEnterFun 'enterPoint
    ?prompts
    '("Point at top left origin of pixmap")
    ?form abPixMapOptionsForm
    ?addPointProc "abPixMapAddPointCB"
    ?doneProc "abPixMapDoneCB"
    ?noInfix t
    ?alwaysMap t
    * (abPixMapCreateColourIcon colour) *
    * Build a small coloured icon in the colour which was in the *
    * original pixmap (or as close to it as we can get given *
    * the colour limitations in DFII) *
    (defun abPixMapCreateColourIcon (colour)
    (let (colourArray
    (line "aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa")
    (setq colourArray (hiCreateColorArray))
    (setarray colourArray 0
    (hiMatchColor
    (foreach mapcar intensity
    (list
    (abPixMapColourGetRed colour)
    (abPixMapColourGetGreen colour)
    (abPixMapColourGetBlue colour)
    (round (times intensity 3.915))
    (hiStringToIcon
    colourArray
    strcat(line line line line line line)
    32 6
    * (abPixMapFillScrollRegion pixmap region cellView) *
    * Fill the scroll region with all the colours found in the *
    * pixmap file *
    (defun abPixMapFillScrollRegion (pixmap region cellView)
    (let (current colours colourNames colourNum button y lpp tfId convert
    icon)
    (setq tfId (techGetTechFile cellView))
    ; Erase any current layer definitions
    (setq current (getq region fieldList))
    (when current (hiDeleteFields region current))
    ; Add the labels at the top
    (setq colourNames (sort (getq colours ?) 'alphalessp))
    (setq colourNum 0)
    ; Remember the colour names to ease lookup later
    (putpropq region colourNames colourNames)
    ; Build the scrollable region on the form
    (foreach colourName colourNames
    (setq icon
    (abPixMapCreateColourIcon (arrayref colours colourName)))
    ; The pretty coloured button, corresponding
    ; to the colour in the original pixmap
    (setq button
    (hiCreateButton
    ?name (concat 'colour colourNum)
    ?buttonIcon icon
    ; Boolean button to enable the layer
    (setq convert
    (hiCreateBooleanButton
    ?name (concat 'convert colourNum)
    ?buttonText " "
    ?defValue t
    ?value t
    ; Create the layer cyclic box
    (setq lpp
    (hiCreateLayerCyclicField
    tfId
    "Choose"
    (leGetValidLayerList tfId)
    ; Make sure field symbol is unique
    (putpropq lpp
    (concat 'lpp colourNum) hiFieldSym)
    (setq y (times colourNum 35))
    (hiAddFields region
    (list
    (list button 0:y+11 32:12)
    (list convert 60:y 20:35 0)
    (list lpp 100:y 150:35 0)
    * (abXpmToLayout) *
    * Main entry point for the pixmap drawer. *
    (defun abXpmToLayout ()
    (let (current)
    (unless (boundp 'abPixMapOptionsForm)
    (abPixMapCreateForm))
    (setq current (getq (getq abPixMapOptionsForm layers) fieldList))
    (when current (hiDeleteFields (getq abPixMapOptionsForm layers) current))
    (putpropq abPixMapOptionsForm (geGetEditCellView) cellView)
    (putpropq abPixMapOptionsForm nil pixmap)
    (enterPoint
    ?prompts '("Use options form to specify file to read")
    ?noInfix t
    ?alwaysMap t
  • carolinenew
    carolinenew over 13 years ago
    for me., personally. convert a picture to RGB matrix is possible, i find this on the iinternet. i am not professional , but i found it is worth trying.
