  3. Returing Empty Set!
  • Views 6345
Returing Empty Set!
FormerMember
FormerMember over 15 years ago
Hai,
 I have written code for pcell instantiation using dbCreateParamInst,it is creating new cellviews in which instants of master are placed but the cellviews are found to be empty ie CIW showing error "Empty Set".But when my friend runs the same code in his system the cellviews are not empty and it is working fine.
What could be the possible reasons for it?How can i eliminate it?
  C10
  • Messi
    Messi over 15 years ago
    Hi C10,
            Check the input you are feeding in the function name inside your procedure...I am not sure,me too am a beginner in SKILL,i had encountered the same problem.It was eliminated when i gave correct input.
    Messi
    Hi Carlton,
    I expect there's a mistake in your code.
    You may have noticed that this answer is rather non-specific, but that's really because your question was non-specific with very little for anyone to go on. I've never seen an error saying "Empty Set" in the CIW - maybe it's something to do with your code or the pcells used? Impossible to know without some clues as to what you're doing and what the precise error message was.
    Kind Regards,
