  3. How to draw a serie of polygons with gradually tilted a...
  • Views 16515
How to draw a serie of polygons with gradually tilted angles
yichun
yichun over 15 years ago
 There is a row of "a" rectangle objects (about a few thousands) and a row of "b" rectangle objects. The "a" objects has a pitch distance of 0.5 mm, while the "b" object has a pitch distance of 1mm. I want to connect "a" to "b" using a serie of simple polygons (with a width of 0.2mm).    Is there a program to do this, or I have to draw it one by one manually.  Thanks.
a      a       a        a         a       a         a          a         a    ......
b            b            b            b              b               b                b               b                b                b  ....
  • Tongju
    Tongju over 15 years ago
    Hi, Yichuan,
    I assume that you are doing this inside the Cadence Virtuoso tool.   You could create path by command "dbCreatePath(cvid lpp pointList width type)"  (in a script).
    The other way is to create a connection cell, which has wires to hook up one "a" to "b". Then, you could instanciate this connection layout cell as an array/mosaic (match your number of "a" boxes). You have option to flatten this mosaic/array so that all the wires come up to the top level.
    Tongju
  • skillUser
    skillUser over 15 years ago
    Hi Yichun,
    If you need to connect each "a" to each "b" in turn, then you could create a path for each pair as Tongju suggested, and this is perhaps the best approach, within some kind of "for" loop.  I would not have thought that you would be able to have a connection cell however, since the horizontal distance between "a" and "b" varies.  There are not enough details in your post to know how large each "a" and "b" rectangle are, or their vertical separation, so any code would have to be a guess, but perhaps something like the following:
    astep = 0.5
    bstep = 1.0
    maxy = ??
    miny = ??
    width = 0.2
    sep = 2 * width
    for(i 0 <maxNumOfRects>
    dbCreatePath(geGetEditCellView() "metal1"
    list(astep*i:maxy astep*i:miny+(sep*i)
    bstep*i:miny+(sep*i) bstep*i:miny)
    width
    This assumes that there is enough vertical separation between the "a" and "b" elements to be able to connect them with a single jog only and not short all the connections with one another.  Put in your own appropriate parameters, I just threw this together as a proof of concept, and in my simple test case it worked.
    I hope that this helps you.
    Lawrence
  • skillUser
    Hi Yichun,
    I just saw the title was "with gradually tilted angles" - in this case, if any angle is allowed, you can just give the end points of each path, something like the following (with path ends adjusted slightly so that they overlap the rectangles and do not leave "notches"):
    ;; other code same as above ...
    list(astep*i:maxy+width bstep*i:miny-width)
    width
    ); end of for loop
    Again, I tested this briefly, but you would need to test with your own parameters.
  • yichun
    Hi Tongju & Lawrence,
    Thank you so much for the help. Your suggestions are very helpful.
    Yichun
