  3. get design variable value?
  • Views 16922
imagesensor123
imagesensor123 over 15 years ago
   as we know, we can get the designVarList=asiGetDesignVarList(asiGetCurrentSession()) , the return result maybe like this
("wselect" "4u")
("thesecond" "value")
("thethird" "value")
and now, i want to get the parameter value ,for example , the first parameter its value should be 4u, but i try several times, it always return "4u", may I get the value of wselect? what's your opinion?
designList=asiGetDesignVarList(asiGetCurrentSession())
foreach( var designList
       if(car(var)=="wselect"
         then printf("%L" var)
              a=nth(1 var)
              printf("%d" a )
         else printf("not find")
zfeng
    Zfeng,
    Design variable values are always strings. If you want to convert it to a number, use a function such as cdfParseFloatString() or aelNumber() to do the conversion.
    Even then, you won't be able to use "%d" to print it, because that is for printing integers - and this clearly isn't!
  • imagesensor123
      thanks a lot! i get it!
    zfeng
