  3. Programm a verilog block to stop simulation.
  • Views 16525
boulot
boulot over 15 years ago
Hi all,
 Is there any possibility to have a verilog block and programme it to finish a simulation when - for instance- his input is on ? It's to save time during corner analysis:
If a signal cross 0V at 10ms, i run simulation for 20ms for covers process variation, so Can I stop automatically the simulation with a verilog block without create an error ?
    Which simulator are you talking about? Is this really a Verilog model or a Verilog-A model (or Verilog-AMS?)
  • boulot
     It's mmsim / spectre simulator. I  run with ADE. In fact If I don't know if I can make this with verilogA.Maybe there is a function. Or maybe there is an option in the simulator for stop her when an expression is validated.  Do you understand my request ??
  • boulot
     I have found on a older topic that I can use the $finish function in a verilogA module. But Can I use an ADE equation as threshold ??
    You cannot use ADE expressions inside VerilogA, but coding a similar check would be trivial in VerilogA.
