  3. modify netlist but don't change the schematic in skill ...
  • Replies 7
  • Views 5312
modify netlist but don't change the schematic in skill function
imagesensor123
imagesensor123 over 15 years ago
   i have a Vpulse source which works like a switch in the output terminal in my design, it  starts with the "0" voltage. In fact, my problem is that, i must get some information like "VoutMaxmum" at the beginning of the simulation, owing to the switch is closed at the beginning so it's impossible to get or retrive the VoutMaxmum . i have thought out a solution with some limitation, i used a parameter "startVoltage" and "endVoltage" to present the Vpulse parameters like" Voltage 0 and Voltage 1" (you can see it in the Vpulse CDF file), and use some function changing the startVoltage value so that we can let the switch keep opened at the beginning. but i think there should be a better way for this, can we do this by modifing the netlist? do you have some good idea?
replacing the Vpulse by Vdc at first-->run-->get VoutMaxmum , by the way, i don't want to change the schematic
zfeng
    Hi Zfeng,
    Why not make the value a design variable and then use desVar() to change it before each run? Your requirement is not that clear to me though.
    Changing the netlist absolutely should not be necessary.
  • imagesensor123
       thanks, yes, i have tried your method, it do really work and get rid of my problem.but for user, i don't want them to add this parameter manually! or user don't like adding  extra parameter in their design. so i think that we can change the CDF of the certain component and change it back when the first simulation finished.
    procedure(getCDF()
    myId=geGetObjectSelectedSet("here is the component you want to change, it's a cellviewID")
    cdfId = cdfGetInstCDF(myId)
    getP = cdfFindParamByName(cdfId "vdc") ;;how can we know each field name in vpulse CDF form?
    oldValue=getP->value
    and then we can change it back, do you think this method is ok?
    zfeng
    You could, although you'll then need edit access to the schematic. Also you need to know the sources somehow anyway.
    Knowing the available parameter names can be found easily enough by looking at the Tools->CDF->Edit CDF form.
  • imagesensor123
        yes, you are right! i met a little trouble when i use my way to change the component CDF,  in the schematic composer i can do it correctly, but when i open the ADE, the problem truns up! i can't save the change any more by function schHiCheckAndSave(),
    *WARNING* geGetEditCellView: Invalid graphics editor window.
    *Error* schCheck: argument #1 should be a database object (type template = "d") - nil
    so i think this is the reason why you said i need to edit access to shematic!
    procedure(editVpulse( source new)
    cvid=geGetEditCellView()
    inst=dbFindAnyInstByName(cvid source)
    oldValue=inst->v1
    inst->v1=new
    schHiCheckAndSave() ;; these two lines can work well only when the composer window(or shematic window is the currentWindow)
    hiRedraw()
     i intend to run the procedure totally in background, it's inconvenient if user have to push the "save and check" button in shematic window. how can we use the schHiCheckAndSave() when the shematic window is not the currentWindow?
    thanks,
    my idea:
    i mean that the shematic window is the current design window, and we need simulate it in some condition such as the vpulse v1=3  v2=3 (like a constant vdc) at the beginning but later v1 need to be fixed at v1=0 in the transient paramAnalysis. so for the first step we want to collect some information(VoutMaxmum) in background before the paramAnalysis
    zfeng
    Use schCheck(cvId) and then dbSave(cvId) rather than the interactive function which assumes that the schematic window is current.
    Similarly you are calling geGetEditCellView - you had a different question about that, so I'll answer that there.
    I still think this is a pretty horrible way of doing this.
  • imagesensor123
       yes, you are right. there is  a veriloga model which named pd in my schematic. and the model has some parameters like "P0". i am trying to get the value of this parameter, i can see there is a CDF parameter of view field in the form when i select the pd and push the "Q" button for editing the properties. i want to use the following procedure to get the parameter "P0" value
    procedure(zfSearchInstance( source ) ;source can be replaced by any instance you want to select ,eg "pd" in this application widSchImager=sevOpenSchematic(sevSession(widTriggerSimulatorWindow))
    cvidImager=geGetEditCellView(widSchImager)
    inst=dbFindAnyInstByName(cvidImager source)
    ; here i want to select the pd and get the field value of P0 in pd model
    paramView->value = "veriloga"
    param=P0->value
    ;i don't know how to write the above code exactly
    schCheck(cvidImager)
    dbSave(cvidImager)
    welcome to your suggestion in anyway.
    Regars,
    zfeng
    There is no need to alter the "CDF Tool Filter" setting - that's only for the edit properties form to filter which properties are shown.
    If you want to get the value, simply do:
    inst~>P0
    or to set it:
    inst~>P0="new Value"
