  3. How to know you are editing FigGroup (Clone) in Edit-In...
  • Views 17466
How to know you are editing FigGroup (Clone) in Edit-In-Place ?
Charley Chen
Charley Chen over 15 years ago
Hi All,
How to convert box using enterBox when you are editing FigGroup (Clone) in Edit-In-Place ?
Thank you,
Charley
    Charley,
    This is covered in Solution 11573240 . The trick is to use the function leGetEditFigGroup() to find out whether you're "in" a figGroup. Not sure what you mean about "convert box using enterBox". The coordinates should be in the same coordinate space as the containing cellView, so no need to convert anything.
  • Charley Chen
    I have a cell (from MakeCell) , when in Edit-In-Place , needs to transforming box
     and then using dbCreateParamInst() , it can put in correct coordinate.
    But now when in Edit-In-Place By  FigGroup , after transforming box  and then use
     dbCreateParamInst() , though it can put in correct coordinate , but not inside the FigGroup , It's on Top Level.
    Thank you,
    Charley
    Charley,
    If you look at the solution I mentioned, it explains how to do this. It's a matter of calling dbAddFigToFigGroup to add your newly created object into the fig group you're inside.
  • Charley Chen
    I will try it.
    Thank you,
    Charley
