  3. How to change the default X-axis for "deriv" function
  • Views 3866
MatthewM
MatthewM over 15 years ago
anybody know how to change the default x-axis for deriv function?? 'cause I want to take deriv relative to another variable.
I tried ocnYvsYplot to change the default x-axis, and then use the return value of ocnYvsYplot as the input parameter for deriv, it fails.
anybody have any idea about this?
Thanks.
    ocnYvsYplot seems to return a list of the results - so you'll need to do:
    newWave=car(ocnYvsYplot(...))
    then you can use deriv on that.
  • MatthewM
    It works!!!
    Thanks so much, Andrew! I really appreciate it.
