  3. How to dump il labels associated with an instance in sc...
  • Views 17487
How to dump il labels associated with an instance in schematic
pmathur
pmathur over 15 years ago
Hi Experts,
I am trying to dump all the interpreted labels associated with an instance in my test schematic. There is only one instance in this schematic. I wrote following code for this task, following piece of code when run interatively give me correct result (correct il Labels. But when I use same in my test procedure I get empty string for iilString. Seems like limitation of cdsParam( ). I am wrong or Is there an alternate way to get the task done.
=========code=====
srcCvId=geGetEditCellView()
instCDF=cdfGetInstCDF(car(srcCvId->instances))
;;Dumping IL Labels
                foreach(_illable  parseString(instCDF~>paramLabelSet)
                      _iilString=cdsParam(_illable)
                      printf("CellName=%L TestcaseName=%L ilLable=%L" cellName testcaseName _iilString)
                      fprintf(tmpport "CellName=%L TestcaseName=%L ilLable=%L" cellName testcaseName _iilString)
                      );end foreach
                fprintf(tmpport "#END IlLables \n")
;;End Dumping IL Labels
Thanks & Best Regards
Prashant Mathur
    You cannot do this. As is said in the documentation for cdsParam :
    This function uses information about the instance currently being drawn in order to compute the data returned by the schematic editor during a redraw. Consequently, cdsParamis only intended to be called as the value of an ILLabel on a symbol, and is not intended for direct evaluation during a program. If it is invoked directly, information on the current drawn instance will not be available.
     If you try to fool it by setting ilInst - it does not work - it always shows the "current" instance (usually the one selected, or last one drawn).
  • pmathur
    Is there an alternate way to get these IL Labels ?
    Thanks & Regards
    Prashant Mathur
    Prashant,
    Not without a reasonable amount of work. You could use the ael.* functions to set things up so that the expressions can be evaluated - e.g. using aelSetLineage() to set the hierarchical path, and calling aelEnvCreate, aelEnvCompile, aelEnvExecute etc  to evaluate the expressions.
    Why do you want to do this anyway?
  • markbeck
    markbeck over 14 years ago
    I'd actually also like to know how to do this.
    One reason to do this, is that you wish to be able to auto generate attached labels displayed on a schematic in order to be able to manipulate / size / move them through scripts.
    When you select an instance, there is no associated labels to manipulate so you have to create them.
    i.e. if you select an instance and query it's textDisplays property, it's usually nil until you select a displayed label associated with the selected instance and move it.  Then, the textDisplay is manipulatable.
    I tried using the ael calls to generate the labels as you suggested, but I have not had any luck.
    For example:
      d_cv = (caar geGetObjectSelectedSet())
      l_env = (list d_cv) ; create the lineage list
      x_env = aelEnvCreate('f); create the ael environment
      aelSetLineage(x_env l_env); set the lineage
      aelEnvInterpret(x_env "cdsPararm(1)") ; Returns nil....
    Is there another (better) way to generate the labels on an instance other than evaluating the .il instance labels?
    Is there something obvious about what I'm doing wrong in the ael example code?
    Mark
    Mark,
    When I dug a bit further, it simply isn't possible - you'd have to recognize the cdsParam() and essentially replicate what it's doing. Far from trivial. "cdsParam(1)" isn't an AEL expression, so evaluating it makes no sense either...
    In order to move and manipulate them, you don't need to evaluate them. You probably just need to create the text display using dbCreateTextDisplay - just as what happens if you've already moved it. The text display only gets created if needed.
    Sorry if that's a bit vague - I've a ton of things to catch up with after being on vacation... so don't have the chance to try this myself.
  • markbeck
    Thanks for looking into this.  I was able to implement the 'selectText' function with the dbCreateTextDisplay() function.
    Mark
