  3. Viewed Layers
  • Replies 8
  • Views 19649
Viewed Layers
J Wilwert
J Wilwert over 15 years ago
I am using cadence - virtuoso - version 6.1.5
I am interested in THE most efficeint method - using skill - to return a list of all viewed layers.  I thought that:
mapc('leIsLayerVisible leGetValidLayerList(techGetTechFile(hiGetCurrentWindow()~>cellView~>lib)))
would be it - however - it did work so well!   Any IDEAS?
MEGA THANKS!! in advance,
John Wilwert
    John,
    Two ways (at least):
    let(((tf techGetTechFile(geGetEditCellView())))
      setof(lpp leGetValidLayerList(tf) leIsLayerVisible(lpp tf))
    or
    foreach(mapcan LP techGetTechFile(geGetEditCellView())~>lps
      when(LP~>valid && LP~>visible list(list(LP~>layer~>name LP~>purpose)))
    I think the first is cleaner and easier to understand.
  • J Wilwert
    Andrew,
    Thanks for your prompt response.
    I have been working with your first suggestion. I am getting different results than I expected.  Here is a sample: _pteHiLayerSetActiveLpp(dwindow('pteLayerPalette1) "M1 drawing")
    t
    Loading layers.cxt
    _pteHiLayerSetNoneVisible(dwindow('pteLayerPalette1))
    t
    let(((tf techGetTechFile(geGetEditCellView()))) setof(lpp leGetValidLayerList(tf) leIsLayerVisible(lpp tf)))
    (("PP" "boundary")
    ("PP" "pin")
    ("PP" "net")
    .... and many more layers!!
    Andrew, in the above, I am viewing only M1 drawing, and when I use the skill code it returns all valid layers! Am I using the setof() function incorrectly? Any ideas?
    John Wilwert
    John,
    I see that behaviour if I am using a Filter (i.e. a "layer set") or the "Used Layers Only" checkbox - because then the "NV" button is only turning off the visibility of the layers shown in the palette, and not those which have been filtered. If I have "All Valid Layers" in the filter, and "Used Layers Only" turned off, I get just the entry layer shown.
    Are you filtering the layers somehow?  Also, there's the Right Mouse->Edit Filter Layers form which could filter layers shown...
  • J Wilwert
    Andrew,
    YES!! - and THANK YOU!
    I do have the "Used Layers Only" box checked.  This will be my "mormal" mode of design.  So, I think what I am really wanting is all layers that are visiable AND being used.  This will take a bit mode skill coding.  Do you have any thoughts?  Maybe,  is there a skill function which is new to release 6.x that might work???
    Again, THANK YOU!!
    John Wilwert
    John,
    procedure(JWgetUsedVisibleValidLayers(@optional (cv geGetEditCellView()))
      let(((tf techGetTechFile(cv)))
        setof(lp foreach(mapcar lpp cv~>lpps list(lpp~>layerName lpp~>purpose))
          leIsLayerValid(lp tf) && leIsLayerVisible(lp tf)
    Will do what you want. cv~>lpps will give you the list of layer-purpose pair objects used in this cellView or anything instantiated (will only appear once the subcells have been loaded though - similar to the palette).
  • J Wilwert
    Andrew,
    AWESOME!!  - THANK YOU!
    I really appreacite the help.
    John Wilwert
  • 2Qforall
    2Qforall over 6 years ago in reply to Andrew Beckett
    Is there a way to pipe or print the output in to a file instead of CIW?
    Andrew Beckett over 6 years ago in reply to 2Qforall
    Assuming you're talking about JWgetUsedVisibleValidLayers in the 9 year old post above, then this doesn't print anything - it simply is a function that returns a list of lists. You can choose to do with that whatever you want - if you want it in a text file, you could just do:
    procedure(JWreportUsedVisibleValidLayers(fileName @optional (cv geGetEditCellView()) "td")
      let((prt)
        if(prt=outfile(fileName) then
          foreach(lpp JWgetUsedVisibleValidLayers(cv)
            fprintf(prt "%s %s\n" car(lpp) cadr(lpp))
          close(prt)
        else
          error("JWreportUsedVisibleValidLayers: could not write to file %L\n" fileName)
    Then use: JWreportUsedVisibleValidLayers("./dump.txt")
