  3. how to get xy coordinates of instance indpendently.
  • Subscribers 150
  • Views 18043
SarathKumarG
SarathKumarG over 14 years ago
 HI all,
          Iam trying a skill code to read all instance names in layout and name is printed as label.I got it but label is came at corner of device.For placing label at midle of device i need to know how we read xy coordinates of instance indepndntly.If anybody knows plz let me know.Below is my code.
 cv = geGetEditCellView()
foreach(inst cv~>instances
geSelectFig( inst )
  ab = inst~>name
points = inst~>xy
dbCreateLabel(cv list("text" "drawing") points ab "centerCenter" "R90" "roman" 1)
Thank You.
    I'm not sure what you mean by "get the xy coordinates of instance independently". The ~>xy attribute tells you the location where the origin of the instantiated cell has ended up. It's entirely dependent on where that that cell's origin is. If you want something that is in the centre of the device, you could use:
    point=centerBox(inst~>bBox)
  • SarathKumarG
     Thanks Andrew,
                         Thnks for your help. it works.I got the label at the middle of instance.But i want height of the label is changed according to size of instance.For that i need to know how we read parameter of a instance.Plz let me know suggestion on this.
    Thank you.
  • skillUser
    skillUser over 14 years ago
    If you want the label height to scale with the instance height, something like the following could do that for you:
    abs(apply('difference mapcar('cadr inst~>bBox)))  ;; label height
    Hopefully this is what you were looking for?
    Best regards,
    Lawrence.
