  3. Creating a magic ruler
  • Replies 7
  • Views 19839
Adhil
Adhil over 15 years ago
Hi All!!! 1. i have always found it tedious to draw a ruler to double check layout parameters such as diff overlap past poly, when doing testchip layout. i want to design a code where when i run my cursor over or close to a side of an object (at the same level or at a lower hierarchy), the side gets highlighted. 2. after clicking, the coordinates of the side gets selected and when i do the same to a side of another object, a ruler is drawn from the first side to the second automatically. 3. this eliminates the need to zoom in and drag and draw a ruler. 4. i have used the gravity option, but i find it insufficient. please your advise and codes are most welcome, i am looking into dbgettrueoverlaps and other related skill functions. adhil
    This is a standard feature in IC614 onwards. Rulers can snap to edges or vertices to avoid the need to zoom in - and the edges are highlighted prior to clicking to allow you to see the target edge.
    You don't say which version you're using. In IC5141 there's also a similar capability using the Turbo Toolbox (I believe, if my memory is correct).
    So writing SKILL seems a bit unnecessary when there are ways of doing this already.
  • Adhil
    yes i was exploring the options that you just mentioned. however, what if you could just select two sides and virtuoso gives the distance between them, i belive this could be very useful
  • dmay
    dmay over 15 years ago
    If you are already clicking twice, then setup one of your mouse keys to be a ruler bindkey. The following example uses Ctrl-mouse2 (hold down the control key, and press your middle mouse button to start the ruler and then do the same to finish your ruler):
    procedure(myMouseRuler()
      let((infix)
        cond(
            (hiGetCurrentCmd(hiGetCurrentWindow()) == "Ruler"
                mouseAddPt()
            (!hiGetCurrentCmd(hiGetCurrentWindow())
                infix   = hiGetCIWindow()->infix
                hiGetCIWindow()->infix = t
                leHiCreateRuler()
                hiGetCIWindow()->infix = infix
      ) ;let
    ) ;proc
    hiSetBindKey("Layout" "Ctrl<Btn2Down>" "myMouseRuler()")
    hiSetBindKey("Layout" "Ctrl<Btn2Down> EF" "myMouseRuler()")
    You can enhance this further by adding gravity. Put these two lines before the leHiCreateRuler:
                gravity = envGetVal("layout" "gravityOn")
                envSetVal("layout" "gravityOn"      'boolean t)
    And restore the previous gravity setting after the leHiCreateRuler:
                envSetVal("layout" "gravityOn"      'boolean gravity)
    Derek
  • Adhil
    Hi Derek.. your code works fine for objects at the same hierarchy, but do you know of away to expand the code to to measure distances between objects at different hierarchys at the same cell view. Adhil.
    You probably just need to change the Gravity Depth to greater than 0 (e.g. 1 or more) to be able to snap to edges down the hierarchy.
    I still don't quite understand why you can't use the standard "smart ruler" capability that's in IC614 and later (unless you're using and older release - you didn't say). This does everything you want and also highlights visually the edge that will be snapped to. Maybe I've missed something?
  • Deeksha D
    Deeksha D over 6 years ago in reply to Andrew Beckett
    Hi Andrew, I just wanted to create a ruler at particular distance(Like a GUI to pop up to ask from the point of cursor to what distance you need to create a ruler and by entering the number in GUI it should create a ruler to that distance) for that I have used dbCreateRuler() function but its not working properly as I expected.
    Andrew Beckett over 6 years ago in reply to Deeksha D
    It might help if you shared the code that you've written because without that it's rather hard to know what you've done wrong.
    BTW, appending on the end of any 8 year old thread is thoroughly against the forum guidelines (please read these).
