  3. model parameters extraction.
  • Subscribers 150
  • Views 17503
imagesensor123
imagesensor123 over 14 years ago
 Hi All,
    it will be a great sorry if some one has posed the question,
i think we can extract model parameters from classical simulation, such as Cgs, Cgd. so my question comes out. does these parameters are related to the analysis method, such as transient or DC or AC? if yes, which analysis can give a more reliable parameter values? could we extract the capacitance from a point where several slept (doesn't work in some time, such as 1ms-10ms) transistors connect together ? by the way, this is a schematic simulation, not post simulation (layout level).
 thanks for replying even that you misunderstand my question, i will be glad to explain it again.
regards,
zfeng
  • ebecheto
    ebecheto over 14 years ago
     The values you are looking for (Cgs, Cds, gm gds ...) are computed for a DC.
    Follow the  steps : Open Calculator, clic on OP, click on your transistor (pops up OPT param. Form), clic on List, Click your selected operating point variable on interst. Then on ADE output expression, click on New expression, click on Get Expression.
    Alternatively you can type directly in Expression : OP("/I0/myTransistor/ " "Cgs")
    Now for multiple values, you may do a DC sweep on whatever parameter you want (vdd, referenceVoltage, W/L etc.)
  • imagesensor123
     Hi ebecheto,
        yes, i think you have unsterdood my question very well. you're right. i have another question, do all of these capacitance parameters can be extracted from a DC analysis? that is to say, they won't change during the transient simulation? what do you mean by "multiple values" ? thanks for your reply.
    regards,
    zfeng
  • ebecheto
    In spectre you can do a sweep on parameter, temperature or variable..
    search sweep  in
     http://www.ee.virginia.edu/~mrs8n/cadence/tutorial1.html
