  3. automatic variable declaration in SKILL
  • Views 17685
tashah
tashah over 14 years ago
 Is it possible to avoid automatic vairable declartion in SKILL? Something similar to perl's "strict".
If not, is this possible in "Scheme"?
Thanks.
    I'm not sure there's really an analagous concept (strict in perl is more related to package variables, I think). You don't declare variables in SKILL anyway. If you try to access a variable which is not bound (i.e. has never been assigned), you'll get an error.
    If you're trying to spot a SKILL variable that should have been in a let() or a prog() to make it local, then you can use SKILL Lint to detect those.
  • tashah
    Thanks Andrew for replying. Lint helps to spot globals, but say I have following situation: myDpl = (list nil 'aProp 1 'bProp 2 'cProp 3) If I pass this DPL to my function and check for: (if (equal 2 myDpl->bPorp) ... ...) DPL will return nil, because there is no "bPorp". Is there any solution to overcome those typo bugs?
  • Austin CAD Guy
    Austin CAD Guy over 14 years ago
     DPL's are free form, you can add or access data in the DPL without restriction. This makes them prone to this type of error. Use a defstruct or a class to limit the slots available to the variable and it will catch the error when you try to access the non existant slots.
    Actually defstruct won't help here because you can still do:
    defstruct(myThing aProp bProp cProp)
    obj=make_myThing()
    obj->bProp => nil
    You could use an association table:
    b=makeTable('pseudoDpl)
    b->aProp=5
    b->aPorp => unbound (so it doesn't flag an error)
    But that wouldn't help you on assignment. So classes are the best way to do it, as Ted mentioned:
    defclass(myThing2 () ((aProp) (bProp) (cProp)))
    c=makeInstance('myThing2)
    c->aProp=2
    c->aPorp => *Error* slotValue: no such slot - aPorp
  • tashah
    Thanks for solutions.
