  3. using a skilll variable in linux environment
  • Subscribers 150
  • Views 16176
egxoner
egxoner over 14 years ago
i know i can execute a linux command in CIW with sh function;
sh(".......")
but i cannot use a cadence variable in linux environment. For example i wanna write my libname and cellname in a text file.
Does anyone has any idea about that??
second question is, this sh function always works in the directory which cadence is invoked. Can we change the working directory??
  • skillUser
    skillUser over 14 years ago
    You can build the command up using the "sprintf" command and/or the "strcat" command - in this case I think you would use the former, here's a brief example:
    let( (cmd)
    sprintf(cmd "someExternalCmd -lib %s -cell %s" libName cellName)
    sh(cmd) ;; could use ipcBeginProcess here
    ); let
    Also, to answer the directory question, the command could have the change directory built in, for example
    cmd = "cd otherDir; someExternalCmd ..."
    With the ipcBeginProcess approach you can interact with a command so you have more flexibility, this is useful if you need to send something to an external command and receive data back from it.
    Hopefully this answers your question.
    Lawrence.
  • skillUser
     I missed that you want to write the library and cell names to a text file, this can be done easily using the SKILL file I/O commands, here's an example:
    fptr = outfile("myTextFile.txt")
    fprintf(fptr "Lib: %s\n" libName)
    fprintf(fptr "Cell: %s\n" cellName)
    close(fptr) fptr=nil
    This opens the file for writing, writes formatted output using the fprintf command and then closes the file (which flushes the I/O buffer).
    Hope this helps.
    Lawrence.
  • egxoner
    Thanks a lot Lawrance. My problems are solved.
