  3. Form popup from library manager causes library manager to...
  • Subscribers 150
  • Views 17089
Form popup from library manager causes library manager to wait...
markbeck
markbeck over 14 years ago
Greetings all,
I'm running Virtuoso IC6.1.5.500.7
I've got a form which is launched from the library manager which works fine, except that when the form is launched it causes the library manager to wait (busy cursor) while the form is up.  If I close the form, it returns control to the library manager.
I know it's possible to spawn a form from the library manager without causing it to wait since the copy form doesn't freeze the lib manager.
Any ideas out there?
Mark
  • skillUser
    skillUser over 14 years ago
    Hi Mark,
    Are you creating the form yourself through Library Manager customization using the cdsLibMgr.il file, or are you talking about a built-in form of the Library Manager UI.  If the latter then there is little that can be done, file a service request, if a change request is warranted then a CCR could be filed either as a bug report or an enhancement request [also, which form/action are we talking about?].  If is is the former, then I think that the form could be made to return sooner using the ?unmapAfterCB argument to hiCreateAppForm(), you would set it to nil - and this is the default, otherwise the Library Manager may be waiting for the form to unmap and return a value before continuing?
    Perhaps I misunderstood the question?
    Lawrence.
  • markbeck
     Hi Lawrence,
    It is a form that I am creating on my own with the cdsLibMgr.il file.  I hadn't used the ?unmapAfterCB option, so it should have been unmaped once the form was created.   Here's a code snippet to see what I was doing:
    ; In cdsLibMgr.il
    lmgrCreateMenuItem("Test" "simple"
                           '(("label" "Run Test")
                             ("callback" ("Test_CB"))
                            ); list
                          ); lmgrCreateMenuItem
    lmgrAddMenuItems("MyToolsMenu" "LCV" (list "Test"))
    ; Defined in a .cdsinit file
    (defun Test_CB (@rest l_args)
      (let ( g_form buttonField)
        ;Main Code
        buttonField = hiCreateButton( ?name 'someButton
          ?buttonText "More Options"
          ?callback "printf(\"pressed\")" )
          g_form = hiCreateAppForm( ?name 'myForm
            ?formTitle "formName"
            ?fields list( buttonField)
            ?callback "printf(\"Done!\\n\")"
            ?unmapAfterCB nil
          hiDisplayForm(g_form)
      ); let
    If you launch the test form, it works fine, but when you try and access the library manager while the form is up, it is still waiting.
    Mark
    Mark,
    Try putting ?dontBlock t in the hiCreateAppForm arguments.
    I've not tried this, but I think that would solve the problem.
  • markbeck
    Yes, that did it!
    Mark
