  3. how is the input.scs generated?
  • Subscribers 150
  • Views 17227
imagesensor123
imagesensor123 over 14 years ago
  i wonder how to generate the cadence "input.scs", as i know, it is composed by several parts, such as, netlist header, netlist, and netlist footer, but i want to modify the netlist and without changing the schematic, for example, adding a capacitor in a circuit node. who has done such works? certainly, we can modify the netlist manually, but i would like to do this by some skill function, is it pratical and possible?
  • berndf
    berndf over 14 years ago
    There are several file manipulation functions
    in SKILL, e.g. outfile, etc.
    But in my opinion file processing is not
    the strength of SKILL.
    So I would recommend using PERL for that
    kind of tasks.
    Bernd
  • imagesensor123
    Hi Bernd,
        thanks for your reply, you're right! i know how to format output, but i don't know the function which can extract the information from the design session, such as analysis info or circuit netlist, i think the ADE artist itself also generate the several parts, and merge them together. so what i want to do is to chang the netlist part after the netlister generate the netlist, and then  merge the serveral parts together. as you said, it's true. the perl is powerful enough for merging files together.
  • berndf
     Check for the 'asi' functions.
    Something like this could return you the run directory:
    o_session = asiGetCurrentSession(  )
    asiGetAnalogRunDir( o_session )
    I don't know exactly if this is what you are looking for.
    Probably OCEAN function can also support your task.
    Bernd
