  3. make exact area of a layout instance
  • Subscribers 148
  • Views 15495
Aritra
Aritra over 14 years ago
     I have a layout instance which have some excess area taken as instance.
When I do (ctrl+f) to view instance itdisplays the instance to be much bigger than the actual layout inside it.
I have set all layers valid & visible too to see if any thing is being unselectable , but the area is indeed empty.
My cadence version is IC 5.10.41
Any one know how to solve this issue ?
    Assuming that you've checked within any instance within that instance, maybe this post will help.
  • Aritra
    I have found an alternative way of solving the problem.
    1. Select all shapes & instances & copy them to a backup cell.
    2. Delete the selected shapes from the original layout.
    3. Run following : foreach(a geGetEditCellVIew()~>shapes dbDeleteObject(a))
    4. Copy the layout back to original shape.
    Some times the code shared by the hyperlinked post, do not work. It is solved by the above method.
