  3. Can we find short between two nets in layout?
  • Subscribers 148
  • Views 19714
Sarvani
Sarvani over 14 years ago
hi all,
        I made a short between VSS, VDD in top level. I need probe at that exact point where VSS and VDD are shorted. Is there any ideas?
  • skillUser
    skillUser over 14 years ago
    This sort of debugging is best done with a Layout Vs Schematic (LVS) tool such as Assura which can aid you finding such shorts (there is a short locator, for example). Otherwise, how would you propose to do it, Mark Net and use your eyes?  Could be difficult if you don't leverage the tools.
    Lawrence.
  • Sarvani
     Thankyou  for your reply  Lawrence. Short's very dificult to find using short locator.Thank you once again.
    The trouble is that it's very hard for any tool to know where the tracks were intended to go, and to identify precisely where the short is - how do you know the intent of the user?
    You didn't say which short locator was being used (because you didn't say which physical verification tool was being used), but they generally work by you "labelling" certain points on the net as being certain, to gradually narrow down the region of the short.
    Layout XL also will detect shorts and put markers where it thinks they are.
