  3. Reference a file in the toolbar file
  • Views 15389
psill
psill over 14 years ago
 Is it possible to reference a file in the .toolbar file rather than defining all the toolbar items in one file?
 WORK_DIRECTORY/.cadence/dfII/toolbars/byApplication/*.toolbars
    You can use the "inheritToolbarsFrom" construct in the toolbar file. Search in cdnshelp for inheritToolbarsFrom for more details.
  • psill
     I have tried the "inheritToolbarsFrom" but our envirnoment causes an error iin the toolbar creation.
    Is there a function I execute to create a toolbar that is defined in the popup toolbar selection?
     Or do I define a toolbar and append the added items with skill?
  • dmay
    dmay over 14 years ago
    I think you can only use the inherit to get the toolbars created by Cadence. I added a toolbar to Layout with the following in my Layout.toolbars file:
            nil
            inheritToolbarsFrom "Layout"
            nil
            name myLayToolbar
            text "MyTools"
            items (
                    nil
                    type            action
                    name            myTool1
                    text            "My Tool1"
                    iconFile        "mytool1.png"
                    callback        "myTool1()"
                    nil
                    type            action
                    name            myTool2
                    text            "My tool2"
                    iconFile        "mytool2.png"
                    callback        "myTool2()"
    There are lots of great icons for the toolbars in $CDSHOME/share/cdssetup/icons/24x24/.
    If you want to do it in Skill, invoke cdsFinder (from shell) or skillFinder (from CIW) and search for "toolbar". There are plenty of commands like:
    hiCreateToolbar
    hiAddToolbarItems
    Derek
    You can inherit any toolbars you like - not just those defined by Cadence. For example, I had two like this:
    Virtuoso_XL.toolbars
                    nil
                    inheritToolbarsFrom "custom"
    custom.toolbars
                    nil
                    inheritToolbarsFrom "Virtuoso_XL"
            ; Cover Obstructions Toolbar
                    nil
                    name CoverObstructionToolbar
                    text "Cover Obstructions"
                    visibleCondition "vsrEnable"
                    items (
                            nil
                            type            action
                            name            abAddCoverObstructionInst
                            text            "Add Cover Obstruction to Instances"
                            iconFile        "placement-blockage-add.png"
                            callback        "abCoverObstruction->addSelectedInstances(abCoverObstruction->getLayer())"
                            enableCondition editable
                            nil
                            type            action
                            name            abRemoveCoverObstructionInst
                            text            "Remove Cover Obstruction from Instances"
                            iconFile        "placement-blockage-remove.png"
                            callback        "abCoverObstruction->removeSelectedInstances()"
                            nil
                            type            action
                            text            "Add Cover Obstruction to CellView"
                            iconFile        "route-blockage-add.png"
                            callback        "abCoverObstruction->add(abCoverObstruction->getLayer())"
                            nil
                            type            action
                            text            "Remove Cover Obstruction from CellView"
                            iconFile        "route-blockage-remove.png"
                            callback        "abCoverObstruction->remove()"
                            nil
                            type            comboBox
                            name            abCoverObstructionLayer
                            tooltip         "Cover Obstruction Layer"
                            prompt          "Layer"
                            value           "Metal1"
                            items           ("Metal1" "Metal2" "Metal3")
                            width           100
                            ; don't really need a callback, so add a dummy one (must have a callback)
                            callback        ""
                            editable        nil
                            nil
                            type            action
                            name            abHilightCoverObstruction
                            text            "Show Cover Obstruction"
                            iconFile        "unhide.png"
                            callback        "abCoverObstruction->hilight()"
                            nil
                            type            action
                            name            abUnhilightCoverObstruction
                            text            "Hide Cover Obstruction"
                            iconFile        "hide.png"
                            callback        "abCoverObstruction->unhilight()"
