  3. CDF parameters connection between AND symbol to schematic...
  • Subscribers 150
  • Views 17302
CDF parameters connection between AND symbol to schematic transistors
Sarvani
Sarvani over 14 years ago
 Hi all,
          I have created a AND(2*1) gate symbol with PW(pmos width), PL(pmos length), NW(nmos width) and NL(nmos length) CDF parameters. And I had a schematic. I need to attach transistors widths and lengths in schematic to symbol(pmos width in schematic to PW , pmos length in schematic to PL something like that.), So that I can directly see the values on symbol from top level without entering into schematic. Let me know is there any solution.
Thank you,
sarvani
    Sarvani,
    Set the pmos transistor's width to pPar("PW"), length to pPar("PL") etc. pPar() is the function used to pass parameters.
  • Sarvani
     Thank you Andrew,  I am very greatful to you. Its working now and sorry for delay replay. Thankyou very much.
    Sarvani
  • breezeleaf
    breezeleaf over 12 years ago
    Dear Andrew,
             I also get another problem need your help.
             I'v made pPar("PW") ...etc worked, But when I CDL out, the netlist become
    .subckt inverter a x
    mxp0 x a vdd vdd pmos w=pw l=pl
    mxn0 x a gnd gnd nmos w=nw l=nl
    .ends inverter
     I can't find where is option can  make CDL out result become
     .subckt inverter a x nl=2 nw=3 pl=2 pw=8
    .ends inverter
    Could you help me?
    Thank you very much
    AlexLiu
    Alex,
    I think it always puts the parameter values on the instance line, not the subckt header. I'm not sure if there is an option to get the behaviour you want (I'd have to do some experiments - so you should contact customer support if you want such behaviour).
