  3. pPar not works for intiger CDF parameters
  • Replies 17
  • Views 35286
Sarvani
Sarvani over 14 years ago
 Hi all,
        Is pPar works for all CDF parameters? I need to pass intiger numbers (like no. of fingers) from top level to bottem level in schematic. But when I enter pPar(NF) through edit object properties options then it doesn't work's. How can I get this intiger values to bottom level? Let me know if any other set up is needed.
thankyou,
sarvani
  • marcelpreda
    marcelpreda over 14 years ago
     Hi Sarvani,
    What means "it doesn't work" ?
    Error/warning message? is it ignored ?
    What is realy written in that field ?
    If I'm not wrong the syntax is pPar("NF") , not pPar(NF) .
    Also the parameter si cASeSenSiTIVe .
    Best Regards,
    Marcel
  • Sarvani
    Hi marcel,
                  I have been getting below warning message. I have NF(no. of fingers) cdf parameter which is an intiger type. When I enter pPar(NF) as default value through TOOLS~>cdf~>edit then below warning message which I am getting. I have pmos width and length cdf parameters (which is type of srtings) which works well in passing parameters. I dont know much about this cdf parameters. Let me know is there any set up is needed?
    *ERROR* The 'Default Value' is not specified for the following component parameter(s): NF
    'Default Value' is a mandatory field for component parameters.
    These component parameters will not be added to the CDF.
    *WARNING* Effective CDF parameter 'NF', cell 'nmos_5V', library 'DIG_CELLS',
    'defValue' field must be specified.
     Thank you,
    Sarvani
  • Quek
    Quek over 14 years ago
    Hi Sarvani
    pPar works as follows:
    a. You have a schematic cellview ABC that contains an instance I1.
    b. In the properties form of the instance, you added the following expression for "nf" parameter:
    pPar("nf")
    c. Now instantiate cell ABC in another schematic (e.g. I2) and add a property named "nf" on this instance. Give it a value (e.g. 123). The value will now be passed down from I2 to I1.
    Please search for "pPar" in $CDSHOME/doc/anasimhelp/anasimhelp.pdf. When in doubt, you can always search for the word through all the pdf manuals in the documentation directory.
    Best regards
    Quek
  • Sarvani
    Thank you Quek. It works now. Thank you very much for your support. I have converted type from int to string for cdf parameter and then selected YES options for parse as Cell and parse as Number. Now pPar("NF") passes to bottom level.
    Thank you,
    Sarvani
  • Quek
    Hi Sarvani
    That's great. Thanks for the follow-up. : )
    Best regards
    Quek
  • Sarvani
     Quek,
                How can I pass parameter from top to hierarchy level schematic for int type cdf parameters in hierarchy level (Passing of cdf parameters from top level to bottom level exists if cdf parameter in bottom level is type of string.)? Previously I had converted type from int to string for cdf parameter and then selected YES options for parse as Cell and parse as Number. Then it passes. But now I don't want to convert cdf parameter of cell from int to string( because it is the cell which is given by foundary.) . Let me know is there any solution for this.
    Thank you,
    sarvani
    Sarvani,
    You can only use pPar() on CDF parameters of type string, which have parseAsCEL set to Yes. You can only use expressions (including operators and math functions) on string fields, and if they are going to be interpreted, it has to know it should be treated as a component expression language (a.k.a. Analog Expression Language) expression. If the CDF parameter is defined as an int or a float, you can only set the value to be an int or a float; an expression would not be an int or a float and so it cannot be used.
    It's quite unusual for foundry PDKs to be using int or float parameters - it sounds as if something is incorrect with the setup and it hasn't been designed with ADE in mind.
  • Sarvani
     Yes that's correct. Then I should copy this cell to another library and convert this type from int to string. But I don't want any error's in simulation for schematic. Is there any error's we got if we change PDK cell from one library to another library? Any precautions needed? I should make sure these cells are same as PDK cells.
    thank you,
    sarvani
    Sarvani,
    It's hard to tell - it rather depends on whether the PDK has other things that depend on the parameters being integers. For example, there may be pcells which require the parameters to be integer (although that generally works OK because the parameters get cast to the right type), but I wouldn't like to say what the impact would be.
    There may be CDF callbacks which also assume the values are a specific type.
    Best would be to contact the foundry and ask them.You could also talk to customer support to discuss this in more detail with information as to which foundry you're using.
  • Sarvani
     Thank you Andrew. We will discuss on this topic on tomorrow. I need to go now. Good night :-)
