  3. Is there any way to generate verilog(not verilog-A) netlist...
  • Subscribers 150
  • Views 3157
Is there any way to generate verilog(not verilog-A) netlist from schematic with SKILL or other batch
clker1
clker1 over 13 years ago
I know how to generate it with verilog-XL simulator. But I want to use script but not GUI to do this. I hate click click and click again.
Can you help me?
    The way to do this (from batch) is to create a run directory once (with the GUI), and then you'll have a run directory containing the si.env file (and .vlogifrc file). You can then do:
    si -batch -command netlist runDir
    from the UNIX prompt.
  • Prakash Shenoy
    Prakash Shenoy over 11 years ago
    Where will the verilog file be dumped after running the above command. I tried it from UNIX prompt, but could not locate the verilog file. Regards,Prakash.
    In the run directory that you specified in the si command. There's not a single netlist by default - but there is a file listing all the input files that need to be passed to the simulator.
    There is a variable you can set to tell it to concatenate everything (at least to concatenate all the modules netlisted from schematics etc - the modules which came from textual views are not merged into this single file). This could go in various places, including your .simrc file:
    vlogifCompatibilityMode="4.0"
    Search on for this variable for more details.
  • Prakash Shenoy
    Thanks Andrew.
    Prakash.
