  3. Object occupying a point
  • Subscribers 150
  • Views 14986
thomas1000
thomas1000 over 13 years ago
Is there any way to tell if an object, say for example it is a metal object, actually occupies a given point (as opposed to surrounding it like a U or O shape).  The bounding box cannot be used because the object may surround but not actually have metal at the point in question.  Expecially if it is a trace.  I need to know if the object actually occupies the point itself with part of its body.
  • marcelpreda
    marcelpreda over 13 years ago
     Hi there,
    You have at least two options:
    #1
    you have the x:y coordinates of the point, just create a small bbox , like (x-0.001:y-0.001) : (x+0.001:y+0.001) and then use
    dbgetTrueOverlaps(
    d_cellView
    l_bBox
    [ tx_layer | t | nil [ lx_level ] ]
    [ g_doRowCol ]
    => ld_fig | nil
     If your object is overlapping this small bbox then it shuld  be found in the ld_fig list.
    Take care: ld_fig is "a list of lists [of lists [of lists [....]]] of db_objects"  (nested lists).
     #2
    If you know the x:y coordinates of the point and also the coordinates of your shape as poligon points you can use an algorithm like "ray casting" , see http://en.wikipedia.org/wiki/Ray_casting_algorithm#Ray_casting_algorithm .
     You have to deal with the points are are on the perimeter: are they in or are they out ?
    BR,
    Marcel
    A couple of additional thoughts. First, you don't need to create a small box - a zero area box will do (i.e. list(x:y x:y)).
    For the ray casting idea, you can find an implementation - abPointInPolygon - here
