  3. How to get the lower level shapes in skill?
  • Replies 7
  • Views 19453
jiangzhou
jiangzhou over 13 years ago
I want to get the lower level shapes in an area.Also,I saw a post in forum.
Code  writing like below:
procedure(abGetOverlapShape(overlap)
  if(listp(overlap) then
      abGetOverlapShape(cadr(overlap))
  else
      overlap
cv=geGetEditCellView()
figList2= dbGetOverlaps(cv list(car(pts) car(pts)) list("M2" "drawing") 32 t)
flattenendFigList2=foreach(mapcar overlap figList2
  srcShape=abGetOverlapShape(overlap)
  dbCopyFig(srcShape cv dbGetHierPathTransform(overlap))
But 'dbGetHierPathTransform' is used for IC6.1.How can I replace it in IC5.1?Thanks!!
    You can use this:
    *                (abGetOverlapTransform overlap)                 *
    * Get the transform needed to transform the shape in the overlap *
    *           into the current cell's coordinate system            *
    (procedure (abGetOverlapTransform overlap)
      (let (transform)
           (if (listp overlap)
               (setq transform (dbConcatTransform
                                (abGetOverlapTransform (cadr overlap))
                                (or
                                  (dbGetq (car overlap) transform)
                                  (list (dbGetq (car overlap) origin)
                                        (dbGetq (car overlap) orient)
                                        1.0)
               (setq transform (list 0:0 "R0" 1.0)))
           transform
  • jiangzhou
    Thank you,Andrew .But if get shape from mosaic,error occurs.
    How to  deal with this problem?Thanks!!
    Rewrite the code to handle mosaics!
    I'm afraid I don't have time to do that now (in the code where I was using this I explicitly checked if the object was a mosaic and made no attempt to handle them - it's not that difficult though). I have a heavy schedule this week and so can only give quick answers on the forum.
    Sorry!
  • jiangzhou
    Thank you!
    If you have time,can you tell me the method to get the origin of every instance in mosaic?
  • theopaone
    theopaone over 13 years ago
     dbGetTrueOverlaps has an optional argument to return the row and column of the mosaic instance of the found shape. Then multiply the rows by the Y pitch and the columns by the X pitch and use that when transforming the shapes.
    Create a simple cell with two rectangles. Then place it in several mosaics with different rotations. Test your algorithm using this simple cell then you can build it into Andrew's code.
    Ted
  • RFStuff
    RFStuff over 13 years ago
     What is mosaic ?
    What the special features in it ?
    An array. If when creating an instance you specify the number of rows and columns then it will be a mosaic, not a single instance. That complicates things a little!
