  3. Skill function to open schematic and check a box from d...
  • Views 15654
Skill function to open schematic and check a box from dropdown
vijay2912
vijay2912 over 12 years ago
Hi
I'm new to skill programming,
I would like to know if this is possible using skill , my problem is
open a schematic-->open a setting form(ex: Create-->Cellview-->from Cellview)--> click on a button
and  disable the checkbox(ex: Display Cellview....remove the tick mark)
I would like to automate this procedure and generate different netlists for lot of cells.
please let me know if this is possible using skill function
regards
Vijay
    Hi Vijay,
    libName="myLib"
    cellName="myCell"
    fromView="schematic"
    toView="functional"
    schPinListToVerilog(libName cellName toView schSchemToPinList(libName cellName fromView))
    Would be the way to create a Verilog view from a schematic. Note, this is not really a "netlist" - it's just a stub view with the I/O defined, but that's what you get when creating cellview from cellview too.
    It wasn't that clear precisely what you were after, but hopefully that gives you a clue. You can find more detail on these functions (and similar other functions) by searching in the documentation (use the Help menu in virtuoso to get at it, or run "cdnshelp" in IC61X or "cdsdoc" in IC5141) for these functions.
  • vijay2912
    Hi Andrew
    Thanks for the reply.
    I'm sorry it was not a precise explaination of the issue, as i'm not supposed to post everything here.
     let me put it this way.
    we have a dropdown menu embeded in the schematic view which is internal to our org. when ever we netlist(hspice netlist) we pull down the menu, select netlist and then click on a button "Hspice Options" and then check the box against "Convert to decimals?" (as true)
    and then click "ok" and the final step is to "Apply" to get the netlist generated.
    I would like to automate this procedure as I have multiple cells to be netlisted. and hence was looking for similar steps in default cadence dropdown to project it to you guys.
    please let me know if its possible with skill
    thanks alot again Andrew
    regards
    Vijay
  • vijay2912
    Hi Andrew.
    Can you please let me know if this is possible through skill coding.
    Appreciate you help.
    thanks and regards
    Vijay
