  3. Skill Script to generate Letters in Virtuoso Layout
  • Views 20537
Celticfox
Celticfox over 12 years ago
Hi All
 I'm looking for a skill script to be able to write letters (upper or lower case) into a form select the height of the letters and the mask layer and the result is an instance in Virtuoso layout of the letters I've written
  • psill000
    psill000 over 12 years ago
    I did something like this when I created rev letters.
    I had to create each of the letters as a polygon and record the points, using a path and merge the shapes gave me the best results.
    Draw all the letters lower left at the origin.
    To change the size of the letter I would use the dbTransformPoint magnification, so draw the letters an easy height to do the magnification, Ex 0.1nm.
    Then the script would parse the string by each character and match the character to the polygon drawn.
    Sorry it is not the code to draw but process I used to do rev letters. I will see if I can find the script to give a starting point.
    Just a thought, attach the letters to the first character or put the letters in a group.
    Paul
  • skillUser
    skillUser over 12 years ago
    Hi CelticFox,
    There is an in-built capability of the Layout Toolbox (previously known as Turbo Toolbox).  Turn on the toolbox with Options -> Toolbox, follow the set up, and then you should be able to use "Turbo Text".  Take a look at Solution Article 11380652
    Failing this, there should be some existing SKILL, but try the above first.
    Lawrence.
