  3. Skill function to create Verilog-Header file by export from...
  • Subscribers 150
  • Views 1168
Skill function to create Verilog-Header file by export from "symbol"
PTRV
PTRV over 12 years ago
I am looking for a solution for the following task: creating 2 Verilog-Header files (with and without power/ground pins) out of the Symbol view.
Can you perhaps help me with this?
Best Regards
  • Li Ting
    Li Ting over 12 years ago
    The public SKILL functions schSymbolToPinList and schPinListToVerilog should give you most of what you want.
    If your symbol already contains the power/ground pins then you can post process the return from schSymbolToPinList to strip out these terminals.
