  3. Is it possible to make a MPP without having to save it off...
  • Views 15565
Is it possible to make a MPP without having to save it off as a template?
Michael L
Michael L over 12 years ago
I have a script that auto generates a MPP template for coax shielding, based on simple user input from a GUI window.  The script then initiates the lxHiCreateMPP() command.  Each time the program is ran, it overwrites the previous template.
Is there a way to create the MPP directly without being forced to save the template each time?  If not, is there a way to automatically set the template instead of the user having to change it manually through the "Create Multipart Path" popup?
  • skillUser
    skillUser over 12 years ago
     Hi Michael,
    You can create a multi-part path by calling the underlying rodCreatePath() function and supplying the appropriate arguments.  This may look a bit tricky to begin with, but if you save an existing template to a text file you can see how the arguments for rodCreatePath should be formulated, since the arguments to leDefineMPPTemplate() are very similar to those of rodCreatePath().  Take a look at Solution Article 11252132 for an example where this has been done and the code incorporated into a procedure that uses it.
    Hope this helps!
    Lawrence.
    You might also find solution 11323850 useful too. This shows how to draw an MPP using rodCreatePath, starting from a template. Kind of the reverse of what you want - but it might help with understanding.
