  3. Regarding metal1 area below the label in metal pin form...
  • Subscribers 150
  • Views 15619
Regarding metal1 area below the label in metal pin format
rajs
rajs over 12 years ago
Hi ,
I have a scenario in standard cell layout ,where i need to check the area availability for 2 via placement below the label on that entire net. we place M1 label on metal1 drawing layer, which may be rectangle or polygon. this label placement is placed on routing grid. Exactly half of the via width sits on left side and remaining half on right side of label justification. How to approach for this? Please let me know if the question is unable to understand.
    Probably you'd use dbGetOverlaps with a box centred around the origin for the label, where the area of the box is the size of the via plus a spacing rule to see if there are any metals in the region. Your question was a bit vague...
  • rajs
    Thanks for giving hint. I will give a try and come back in case facing any issue with proper framing of question.
  • tweeks
    tweeks over 12 years ago
    Could you use lxComputeViaParams()?
