  3. Undo/recall selection
  • Views 3921
blankman
blankman over 12 years ago
I'm looking to auto store a selection set in layout to create the option of an undo/recall selection. It would involve storing the selection set automatically each time a set of objects are selected. How would I go about calling a function automatically in this manner, ie without need for a bindkey?
Rgds,
Brian.
    Hi Brian,
    This is standard functionality in IC61 (I can't remember precisely when it was added, but it's definitely in IC615 and IC616, and earlier too I believe).
    You can turn it on from Options->Selection (turn on Auto Store), and then you can access Edit->Select->Previous Saved Set (or Next Saved Set). You can also explicitly save a selection (with a name) from the Edit->Select menu. The functions you would put on bindkeys are: geSelectPreviousAutoStoreSet() and geSelectNextAutoStoreSet().
    You didn't mention which version you were talking about, so hopefully this is sufficient.
  • blankman
    Andrew, thats perfect does just what I'm looking for, thanks, Brian.
