  3. How to get the "Top Cell" from a given library ?
  • Subscribers 150
  • Views 4523
Charley Chen
Charley Chen over 12 years ago
Hi All ,
I have no idea to get the "Top Cell" from a given library ?
Could you help me ?
Thank you,
Charley
  • Li Ting
    Li Ting over 12 years ago
    There is no standard for defining a top cell for a library. A library is simply a collection of cells with no special provision of declaring a top cell.
  • Charley Chen
    Hi Li Ting,
    Each cell in library could be a top cell . Could i know which cell has the max hierarchy length(or level) ?
    Thank you,
    Charley
  • Li Ting
    Hi Charley
    It is true that each cell in the library could be a top cell.
    The depth of a hierarchy is not stored in the database nor in the library or cell's property bag. This information can change at any time when any cellview in the hierarchy is updated.
    To get this information will involve process each cellview in the library and for each cellview travers its instance chain to determine the hierarchical depth of each cellview. Using the pcdb* SKILL API functions can help in reducing the process time as the actual database files do not need to be opened.
    Li
     I would do it the other way around - look (using pcdb functions, as Li said) all cells referenced from each cellView, and if you find any cellViews in the library which aren't referenced from anywhere, that's a top cell.
    Of course, it's always possible that a cellView is referenced from a different library, but if you're keeping to a single library, that's how I'd approach it rather than looking at the hierarchy depth. I used a similar approach many years ago in a tool that manipulated stream (GDSII) files.
  • Charley Chen
    Hi Li Ting,
    Thank you, I will try it.
    Charley
  • Charley Chen
    Charley
