  3. Finding duplicate pins in schematic/Layout
  • Subscribers 150
  • Views 3999
garry01
garry01 over 12 years ago
I have duplicate pins in my layout and schematic but when i am acessing the pins duplicate pins are reported only once. I am trying to create text file listing all the pins in schemtic and layout. Please suggest me a way such that redundant pins are reported.
    I don't understand what you mean by "duplicate pins are reported only once". Reported by what? Please explain what you're doing currently and also why it matters to you about having duplicate pins (which is a perfectly reasonable thing to do).
  • garry01
    Sorry Andrew i was not clear in my Question.
    Though most of the time its good to have but sometime we have faced issue and these issues are caught at a very later stage of the design which cost 2-3 days.
    So again my question was suppose in a schemtic i have multiple pins with same name and i want to list them with number of occurence how it can be done.
    now if i am accessing scehmatic something like:
    cv =  geGetEditCellView()
    cv~>terminals~>name
    it will list all the pins once so i am not able to figure out a way to count the number of duplicate pins.
  • tweeks
    tweeks over 12 years ago
    You (apparently) want:
    cv->terminals~>pins~>net~>name
  • garry01
    Thanks . That is what i wanted.
    Terminals are the logical external connections to a block whereas the pins are the physical manifestations of that connection. As a result, it only makes sense to have a single terminal for each logical connection, but you can have multiple physical connection points.
