  3. dx==0.05 is not true even dx is 0.05
  • Subscribers 150
  • Views 1656
Venu Ch
Venu Ch over 12 years ago
 Hi all,
I have written below code for increasing metal widths of source and drain of every mos device in layout. This is because pcell default souce and drain metal widths are minimum.  I don't want minimum metal widths. So I palnning to identify minimum metal widths for each and every mos and increase it by 0.01.
m1=list("M1" "drawing")
polyVia=techFindViaDefByName( techId "PCCAM1")
procedure(CSVsourceAndDrainMinWidth()
cv=geGetEditCellView()
foreach(inst cv~>instances
when(car(parseString(inst~>cellName "egpnlvt"))=="f" ;this is for getting mos device
when(inst~>prop    ;this is for make sure it is pcell
m1Lay  =dbGetOverlaps(cv inst~>bBox m1 2 t)
abCopyOverlapShape(m1Lay)
m1Lay2=setof(x tempObjs x~>lpp==m1)
result=dbLayerTile(cv "y4"  m1Lay2 )
tempObjs~>lpp=y1
foreach(objct result
dx=abs(caadr(objct~>bBox)-caar(objct~>bBox))
dy=abs(cadar(objct~>bBox)-cadadr(objct~>bBox))
printf("%f  " dx)
when(dx==0.05
print("yes")
m1Lay3=dbLayerSize(cv m1 list(obj) 0.01)
y2y3y4prBoundary=nconc(tempObjs result)
foreach(deleteLayer y2y3y4prBoundary
dbDeleteObject(deleteLayer)
 procedure(abCopyOverlapShape(objcts)
tempObjs=nil
flattenendFigList2=foreach(mapcar overlap objcts
 srcShape=abGetOverlapShape(overlap)
tempObj=dbCopyFig(srcShape cv dbGetHierPathTransform(overlap))
tempObjs=cons(tempObj tempObjs)
procedure(abGetOverlapShape(overlap)
if(listp(overlap) then
when(overlap
      abGetOverlapShape(cadr(overlap))
  else
      overlap
In some cases dx is 0.05  (please see in output) it is not printing "yes"
Output:
0.050000  0.960000  0.050000  0.050000  0.960000  0.050000  0.050000  0.082000  0.050000
(db:0x25bce793 db:0x25bce792 db:0x25bce794)
Thank you,
Chandaka
    This is due to floating point rounding errors, which will happen in any programming language. There have been numerous posts on this and lots of discussion about this in pretty much any programming language which uses IEEE floating point arithmetic. See this post where I describe the problem.
    What it boils down to is that you should never do an exact comparison of two floating point numbers unless you can be absolutely sure that they have originated from the same source. What you should do instead is:
    when(abs(dx-0.05)<1e-4 ...
    Or some small "epsilon" which is smaller than the resolution you need. If your database units are 1000 DBUPerUU (i.e. a database unit is 1nm), then something smaller than 1nm absolute error must be rounding error.
  • tweeks
    tweeks over 12 years ago
    Some cope with these issues by computing coordinates as fixnums instead of flonums.
    It is unfortunate that the SKILL database API uses floats to represent coordinates, which the fab is going to convert back into integers anyway.
    Aren't they stored in the OA/CDB file as integers as well (hence the "DBUPerUU" constant)?
    They are stored as integers in the database, but the APIs deal with user units rather than database units. Having to always deal with database units would be really unfriendly (the OA APIs also work with user units rather than database units).
  • Venu Ch
    Thanks Andrew for detailed explanation. It is working now.
    Thank you,
    Venu
