  3. How to know a cell has been opened finished ?
  • Views 15188
Charley Chen
Charley Chen over 11 years ago
Hi All,
When i open a large cell , it needs time to open it , I want to do something after the cell has been opened finished .
Thank you,
Charley
    Charley,
    If you are calling dbOpenCellViewByType(), then it won't return until the cellView has loaded - so I don't see why you need to know when it has finished loading - it will have done.
    If you're talking about opening in the layout editor, you should be able to use the userPostInstallTrigger (registered with deRegUserTriggers) to do this (I think - I've not checked).
    It's not that clear to me what problem you're trying to solve.
  • Charley Chen
    Andrew , I use layout editor to open a cell . Because when there is a large layout design , it needs to load many cells (e.g. pcells ... , ) ..., it spends much time , and i want to do something when cell is finished loading. I don't want to wait it just sit there and determine . Thank you, Charley
  • Charley Chen
    Andrew ,
    From your hint  , i got the solution.
    Thank you,
    Charley
