  3. How to get the corner session or object in the adexl with...
  • Views 19085
How to get the corner session or object in the adexl with skill
Derek WANG
Derek WANG over 11 years ago
Hi All
I want to retrieve the information of the corner setup in the ADEXL.
by going through the documents and Forums, I find out how to get the variables and model setup.
but I cannot get the setup of the "tests" inside the corner setup.
Does somebody know how to do it?
another relevant question is that:
from the function of ADE XL (axl*), I can get the handle of the corner.
I'd like to know how to reach the object of the corner from its handle.
As the functions of ADE L ask the object of corner as the input.
Best Regards
Yi
    Hi Yi,
    I'm not sure what you mean by the "setup of the 'tests' inside the corner setup", or "how to reach the object of the corner from its handle". What do you mean by the "object"?
    I also don't understand what you mean by "the functions of ADE L ask the object of corner as the input" either. As far as I know, no ADE L functions expect a corner - so I don't know what you're talking about here.
    (BTW, I am very familiar with the ADE L and XL APIs)
  • Derek WANG
    Hi Andrew
    Sorry that I do not make my question clear.
    • Regarding the "setup of 'test' inside the corner setup"
    In the bottom of ADEXL corner setup popup window, you can select/deselect "Tests" for each defined corner case.
    what I want is to retrieve this information, whether "Test_A" has been selected for "Corner_B". I do not  find the suitable functions for this in the document.
    fortunately, I find a function which is not mentioned in the docuemtn, "axlGetCornersForATest()", it can return the enabled corner simulations for a perticular Test. It provides the info I asked above in the other way. The drawback is that, the return value of such function is the list of corner simulation after the combinaton of all the temperature, design variables etc. So, instead of getting one original setup of the corner, I get the expanded version. Moreover the corner name has also been extened with aditional suffix.(for example, origin name is "PVT", after expanding, it becomes "PVT_1, PVT_2..."). It takes me a lot effort to obtain the info I need. and I cannot solve the issue when the original coner name contains "_".
    • regarding the object and handle for a corner, this is the story behind:
    For the function "axlGetCorner()", the return value is a "hanld of a corner( x_corner)", but I cannot access the relavent info about such corner via the "~>" operator and the handle of the corner. In order to get the setup of such corner, I can only depend on the functions provided by cadence.
    On the other hand, from the "Virtuoso Analog Design Environment L SKILL function reference"(release on February 2012, Product Version 6.1.5), there are also some functions about the corner, like "asiGetCornerModelSelevtionList()", it requires an input of "Corner Object (o_corner)". Such functions make me feel that the corner object in adexl may also exist, then I can use the "~>" operator to retrieve the info I need, not limited by the functions that Cadenece provide.
    So it comes to my question, when I have the handle of the corner, how can I get the object of the corner?
    Best Regards
    Yi
    Hi Yi,
    axlGetCornersForATest() is documented (maybe it wasn't in the version you're using, but it is now). However, I understand your problem - it gives the expanded corners, which may not be what you want. I'm sure you could write some code to correlate it with what axlGetCorners() returns, but it ought to be simpler.
    There is an API to return the tests which are disabled for a particular corner, but it's private. You should contact customer support to ask for a public API for this (it's come up in a previous CCR, but the main goal of that CCR was to find the total number of simulation points, not the actual corner names - this resulted in the addition of axlGetSetupInfo() - which won't help you).
    The asi.*Corner functions are obsolete. These refer the old IC5141 corners tool which was an add on for ADE (L). I have filed a request for these to be removed from the documentation since they are of no use in IC61X because the corner mechanism is completely different.
    With ADE XL, the object handles are integers, and so you cannot use the ~> operator on them - so you must use the documented API. Even with "asi" objects (for ADE L, or for ADE XL test objects), the usage of ~> on these objects is not documented and liable to change, and you should use the documented API only in those cases.
    Kind Regards,
