  3. Asking SKILL Code for Virtouso
  • Replies 20
  • Subscribers 153
  • Views 27107
archive over 20 years ago
I'm new to the forums and really need this code.
Here goes, I would like a SKILL code for Virtouso that goes something like this. It's a "Flip Command". The code should flip any object-->instance, path/wire, polygons, rectangle, contacts etc. either "vertical" or "horizontal". And added to that, if you select multiple objects, you could also flip them "vertical or horizontal". it's like a picture when you flip it or mirror it.
like, the objects are selected, "123" when FLIPPED all objects becomes "321".
Thanks. I hope someone could help me, i have other request for Virtouso but they don't have any forums.
Originally posted in cdnusers.org by wonderkamote
    My first reaction is why don't you do this without skill in Virtuoso? Just select the
    things, type m to move, click the swap button from the form, and click the right
    mouse button to place them flipped.
    If you want to do this with skill, you not only need to swap each instance but also
    calculate a new origin for each instance.
    Greetings, William.
    I have an example how to rotate instances here. It is not difficult to modify this for
    flipping only. However, only the orientation is modified, not the origin.
    procedure( wrRotateInst( )
      let( ( wrOrient)
        foreach( instancepointer geGetSelectedSet( )
          unless( null( instancepointer->orient)
        wrOrient = instancepointer->orient
        case( wrOrient
          ( "R0"
            wrOrient = "R90"
          ( "R90"
            wrOrient = "R180"
          ( "R180"
            wrOrient = "R270"
          ( "R270"
            wrOrient = "R0"
          ( "MY"
            wrOrient = "MYR90"
          ( "MYR90"
            wrOrient = "MX"
          ( "MX"
            wrOrient = "MXR90"
          ( "MXR90"
            wrOrient = "MY"
        ) ;; case
        instancepointer->orient = wrOrient
          ) ;; unless
        ) ;; foreach
      ) ;; let
    Originally posted in cdnusers.org by relyveld
    Relyveld and William,
    The "Virtuoso SKILL forum" is known here by the "Custom IC Skill" .
    I will now move this thread to that forum.
    Administrator
    Originally posted in cdnusers.org by Administrator
    Attached is some SKILL code for providing a convenient function for doing in-place
    flipping and rotation. See the comments in the code for more details on using it.
    Originally posted in cdnusers.org by adbeckett
    abFlip.il
    Apologies for the previous code I posted - it was missing some auxilliary functions defined in another file. This time I've attached the combined code (renamed slightly to follow the normal conventions for customer code - having an uppercase prefix) - which includes all the auxilliary functions.
    CCSflip.il
    Thanks adbeckett.  This looks really useful.  However, being the newb that I am to SKILL....how do I use this file with Virtuoso?  I'm guessing that I might add a load statement to my .cdsinit file to load the whole file at startup.  But then how do I make work?  Do you use this with bindkeys, or does this somehow work dynamically with the right mouse button after the 'move' bindkey is hit?
    I'd appreciate any help you could give on this since I can see myself using this a lot.
    Originally posted in cdnusers.org by bigWayne
    You would add a line to your .cdsinit file:
    load("/path/to/CCSflip.il")
    and then define a bindkey (for example):
    hiSetBindKey("Layout" "n" "CCSflip(?orient "MY" ?relativeTo 'upperRight ?mode 'copy)")
    with whichever bindkey you want, and variant of the function you want (see the comments at the top for examples) in the final argument string.
  • Vaughn
    Vaughn over 16 years ago
     Can the administrator find the proper line to CCSflip.il
    Vaughn
    I think the attachment links got messed up in the transfer from cdnusers.org to the new Community Forums.
    Anyway, please find attached the latest version of CCSflip.il
    CCSflip.il
  • Vaughn
     Andrew,
    The past to the attatchment does not exist.
    https://www.cadence.com/Community/CSSharedFiles/forums/storage/48/24228/CCSflip.il
    Or I just can not view it. ... Yes I am logged in. ;)
    Looks like a fault with the community forums. I've logged an IT ticket to get this fixed.
    In the meantime, if you can log onto support.cadence.com you should be able to find CCSflip.il - just search for CCSflip or solution number 11024872
