  3. poCellNameMap not resolving cell name collisions
  • Views 15584
JayR
JayR over 11 years ago
When I use Xstream to stream out, Xstream is adding a bunch of _cv1, _cv2, et. al. suffixes, even when the cell name collisions are not real.   In other words, the lib, cell, and view are all exactly identical, but XStream still treats these as collisions when in fact I only need one STRUCTURE streamed out in the first place.  After all, it's the exact same cell.
I tried to resolve this using poCellNameMap, and even then XStream still tacks on _cv1, _cv2, etc. even after poCellNameMap puts its own sauce on it.   For the life of me, I can't get rid of these stupid suffixes without postprocessing the GDS.
Surely there is a much simpler solution to this?     Haven't others seen this problem before?
    Really? The only reason I can see that Xstream would do this is if the lib/cell/view in question is a PCell (a Parameterised Cell), because then it needs to write out a different structure (stream name for a "cell") for each variant (based on the parameters passed to the PCell), and so would need a unique name. If it's the same lib/cell/view referenced in multiple instantiations, then there would be no collision and no need to write it out more than once. I've never seen it doing that, and it would be a bug if that was happening - you should report this to customer support.
    Using poCellNameMap won't allow you merge different masters into one - if it thinks there's a good reason to write out multiple structures, it will continue to do so, and of course it needs to ensure they have unique names.
  • JayR
    The hierarchy is something like this:
    libA cellA  ->   libA cellB
                     ->   libB cellC
                                 libB cellD
                                 libA cellB
    Xstream is treating the two instances of "libA cellB" like a collision, and suffixing _cv1 and _cv2 to them both.  It seems to be because libA is referring to libB, which is referring back to libA again.   I tried poParamCellNameMap to see if that affects anything, and...well...the good news is, it works exactly as it's supposed to--for Pcells.   But these aren't Pcells, so that remains unchanged.
    I've tried working through our account on quite a number of obvious bugs, and that isn't getting very far, so I tried here.  The problem is so visible, I figured others have already worked through this somehow.
    thanks, though, Andrew,
    Jay
    Jay,
    Sounds odd. What version (and subversion) are  you using (Help->About in the CIW reports this)?
    Also, if you have a case number for this, please let me know and I'll look into it.
