  3. create a Symbol from schematic with skill
  • Views 17321
enahmedfathy
enahmedfathy over 11 years ago
I want to create a Symbol from Schematic  with specific options:
1. I want to make a rectangle shape
2. place the GND pin at the bottom of the shape
3. place the VDD pin at the top of the shape
4. place input pins at the left of the shape
5. place all other pins at the right of the shape
I want to know how to do this by skill as I am new to skill and also I tried different set of skill methods and still couldn't get to achieve the requirements.
  • skillUser
    skillUser over 11 years ago
    Look at the "tsg" SKILL function and the associated description of the Text-To-Symbol Generator in the documentation - in the section "Complex File Example" you can see the specification of some pin locations. I think this will do what you are asking. Regards, Lawrence.
  • enahmedfathy
    Thank you, actually this function helped me a lot and now I have 2 more questions: 1. how to create tsg template file by using pin names from schematic 2. Is there away to generate tsg description file from pinlist ?? or from schematic ?
