  3. Changing properties of instance selection box
  • Views 17608
archive over 19 years ago
Hi all, anyone aware of how to change the properties (thickness, color, etc ...) of the selection box in Composer ? Thanks, Michele
Originally posted in cdnusers.org by micheleq
    The 'properties' (thickness and color) for the selection box in the Cadence Symbol Editor come form the system layer purpose pair (lpp) 'instance drawing',
    which is assigned to the display packet 'red' in the technology file.
    If you want to change the thickness and color of them you have to
    assign a other display packet to 'instance drawing' lpp in your technology
    file. But this changes the color appearance of every shape drawn with the
    lpp 'instance drawing' no mater if it is for symbols selection box,
    or any other stuff in schematics or layouts.
    Or modify the display packet 'red' in the display.drf or your local
    display.drf file. But this will chance the appearance of every layer
    purpose pair which is assinged to the display packet 'red'.
    Bernd
    Originally posted in cdnusers.org by bernd.fischer
    Bernd, how does it work when you create a library without a techfile ? Also is there any way to do that by using SKILL ? Thanks, Michele
    If you create a library without a tech file, or without attaching it to a techfile, it gets automatically attached to a library called cdsDefTechLib - which contains all the system layers - such as instance/drawing. So it is no different.
    Originally posted in cdnusers.org by adbeckett
