  3. How to generate a gds file from a skill file from command...
  • Subscribers 150
  • Views 16735
How to generate a gds file from a skill file from command line.
ahmaddaiict
ahmaddaiict over 11 years ago
Hello all;
 I I need to generate a gds file from a skill file..please recommend me your suggestions.
one option is to generate a layout from the skill file using  virtuoso -nograph skilfile.il command. The generate a gds file using strmout command.
Is there any single step to generate a gds file from a skill file.
Thanks & Regards
Ahmad.
  • theopaone
    theopaone over 11 years ago
    Here is some code I used to generate a GDS from an open cellView. You probably could remove the virtualMemory line.
    procedure( MPCgenGDS(@key (cvId geGetEditCellView() ) outputFile layerMap )
        xstSetField( "library" cvId~>libName)
        xstSetField( "topCell" cvId~>cellName)
        xstSetField( "view" cvId~>libName)
        xstSetField( "virtualMemory" "true" )
        xstSetField( "strmFile" outputFile )
        xstSetField( "layerMap" layerMap )
        pipoDisplay(transStreamOutForm)
    You can also run strmout in batch mode using a template file or specifying the options on the command line. More info on these options are found in the Data Translators Reference in cdnshelp.
