  3. Generating bounded schematic from layout
  • Subscribers 150
  • Views 22280
Ron M
Ron M over 10 years ago
Seomtimes, in RF design, we are starting from layout and would like to create a schematic based on it.
We would like to generate a schematic from layout-xl view and keep the binding (and in the future the connectivity) between the layout pcells and schematic instances (so, when we change the parameters in pcells we can update the schematic and vice versa).
I do see skill functions for maintaining binding between instances, however how do I mark the full schematic as connected to the layout view (I.e. generate the phyConf view)?
Ronen
  • theopaone
    theopaone over 10 years ago
    If you are going from layout to schematic you have to have the following:
    1. A symbol for each cell and pcell
    2. Logical connectivity in the layout (nets and instTerms)
    3. No devices drawn flat
    You can create the schematic by placing the symbol instances and creating instTerms to re-create the connectivity. I think you have to add a wire stub to each pin but the connectivity model is generated by the instTerms.
    If the layout does not have the logical connectivity, or if you have flattened devices, you may have to extract it to a CDL netlist and input it as mentioned here:
    http://community.cadence.com/cadence_technology_forums/f/48/p/23540/1314794#1314794
    After you create the schematic, iterate through the instances in both the layout and schematic by instance name and copy all the properties.
    For binding the schematic to layout, see this:
    http://community.cadence.com/cadence_technology_forums/f/38/t/34692
  • Ron M
    Thanks for the info. I was looking for a way to automate the process.
    Ofcourse, we have symbols for these pcells, we are using them to generate layout from schematic in layoutXL.
    Currently we are looking for a way to do it the opposite way automatically.  We are less concerned about connectivity (which may not exist at initial state) and more concern about synchronizing between layout and schematic.
    Do you have a skill example of using "bnd" functions?
    Hi Ronen,
    I'm not sure you'd necessarily need to use the bnd functions - probably keeping the instance names the same and using lxSetConnRef to set the connectivity reference for the layout would be sufficient.
    If you really need to you can use bndSetObjectsBinding (given the dbId of the schematic and layout instances) or bndSetInstsBindingByName (which uses the names of the instances) - but you'd have to do lxSetConnRef first. They're fairly straightforward to use from the documentation.
  • Ron M
    That is the missing link that I searched for and if it also binds the instances when the names are the same it will be even more perfect.
    Ronen
